Under hood insulation???
Discussion in 'The Garage' started by steve_kibbe, Aug 29, 2005.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I am in the process of prepping my truck for paint and wonder should I replace the insulation under the hood or leave it off.
    I'm in South Carolina, so extreme cold temperatures are not a concern.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I always pitch mine, even up here in the north! :D
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Well, I think it has a couple of purposes. One, it insulates the hood from the heat of the engine to probably protect the paint on the outside of the hood. Two, it serves as a blanket to smother flames in the event of a fire, which is why it's held on with cheap plastic fasteners.
    So... I'd replace it, but that's just my opinion.
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Very interesting. Never thought of that before but it makes sense. :thinking:
  5. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeppers, .. it's not a perfect system, but it helps... a lot. If nothing else, it will usually help keep it slowed down for a while until something else can be used to knock it down.
    It is also wise to replace them every so often. Otherwise it falls down on the fire, while it's also loaded up with grease and grime from years and years of being under there... which probably won't help much.
  6. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    What about for a diesel? Same theory apply?
  7. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I would imagine so..
    I have made more gasoline vehicle fires, but still have been to a few diesel vehicle fires as well.
  8. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Mine is greasy!
    The hood insulation on my 82 K20 diesel is SOAKED with grease and sludge!..I bet if my motor caught fire,it would be like throwing a gallon of diesel on the flames when it falls on the motor!..maybe I should rip it out!- :thinking: -its already got a few spots missing,and every time my head rubs against it,I come out looking like the "Fonz".. :doah: :( :mad: ..
    It takes forever for snow to melt off my diesel's hood too--but my 79 C10 without insulation melts it in 5 minites!--another good reason to ditch it!..I think it does help kill the noise from the diesel motor though.. :crazy:
  9. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    Cost is $38 on lmc and serves good purpose for multiple reasons as stated before so it might be worth it
  10. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    I remember reading either here or somewhere else that someone posted they had taken their insulation out and the heat from the motor caused the paint on their hood to bubble. :doah:
    I've had a couple cars with no insulation though and never had that problem :dunno:
  11. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    What is the insulation made of? Rather then paying LMC $38 could one make there own?
  12. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I've seen people use the reflective insulation that can be bought in rolls. Don't know how well it will put out a fire, but I'm sure it insulates just fine.
  13. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    A lot of good points to consider.
    I was wondering because my DD doesn't have it, didn't come with it from the factory either. My 72 doesn't have any either.
    As for deadining the sound, I think thats a waste of time :D ever heard a 6.2 with dual glass packs and some tls's rolling down the interstate :yikes: :ears:
  14. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    I dont think that hood insalation would help you very much on quiting that down. But I bet that sure is loud. :laugh:
    To bad you are far away from me because I am just about to take mine off and it is in good shape, and I would let you have it for cheap. :D
    later
    jmd
  15. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    sorry for the noob question :D but what exactly is the insulation for ? I've heard if the engine catches on fire it will drop down and smother the fire.
  16. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    mine cought on fire!!!!!! it is gone now :haha:
  17. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    This adds a new twist to it. :thinking: :thinking: :thinking:
  18. RootBreaker
    Nov 29, 2001
    5,117
    173
    gotta realize one thing.... I didnt have an air cleaner :doah:
    was 17 and trying to see if i got better power.... but then backfire through carb... cought fire and I decided to put the air cleaner back on....
  19. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I replaced mine with aluminum bubble insulation....
    makes the engine compartment very nice looking, doesnt hold grease and oil, insulates better than the jute felt oil rag mouse stuff
  20. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    REMOVE IT! if it is old it will become flamable. it is fiberglass like thats in house but of a higher quality. i took mine off when i got the truck for my b-day and i live in the bay area where it has been 103*+ lately and no bubbles in the paint or anything like that. for an older vehicle it is much safer to remove it. i may only be 17 but i know what im talking about. trust me on this one. take it out
