Undercoating removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Sep 2, 2001.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Anyone know of an easy way to get rid of this vile stuff? I've been chipping at it bit by bit for days, and need to come up with a quicker way.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Have you tried softening it up with a solvent? I don't think there is an easy way other than scraping it off...but if its soft it may be easier to scrape.
    Rene
  3. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've tried a couple of different solvents, and nothing will actually cut into it - it's almost like Rhino Lining - whenever I get a spot to start lifting, it peels off in a good size chunk, and it's pretty stiff. Whoever the previous owner of this crossmember was was serious about rustproofing - the stuff is about 1/4" thick.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Its not very environmentally correct...but have you tried gasoline? Every undercoat I've seen just gets gooey and melts when gas sits on it...
    Rene
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Haven't tried gas yet - I'll give it a whirl in the morning[​IMG] I'm almost to the point of putting a knotted wheel on the grinder and covering the garage with black stuff - except the wife would probably be a little perturbed at cleaning undercoat crumbs out of the washer/dryer.
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I feel your pain...Gas will soften it, but it'll still be a messy disgusting job. I'd soften it up and use a good 1 1/2" scraper. any wider and you won't get enough pressure along the edge of the blade.
    Rene
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Cool deal! I learned my lesson now - if you want an easy job, do not buy junkyard parts from places that salt the roads[​IMG]
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Yes...welcome to hell [​IMG]
    Rene
  9. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    My "new" raddiator support was loaded with undercoat from previous owner. I had luck with hubby's comercial size power washer. It took some time but most came off. To finish it, I used a wire wheel on our drill. Living in Vermont, I don't think I could have found one without that miserable stuff on it.
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear, dana 44 front, TIRED ol 305
  10. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Hey, just did this about a week ago. Used a pressure washer and denatured alcohol. Rips the crap off ! Got the alcohol by gallon from Lowes for 9.40, have a 3500 psi washer. Took everything off, I have POR 15 to spray on it, but haven't gotten to it yet. Just a note, if you don't want to be using alcohol on your skin, cover everything, and also your driveway, took me some time to get that crap off driveway. Just my 2 cents.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  11. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    HA HA!! I had this CRAP on the insides of the rear fender wells on my '71 Elco. Tried gas, sovent, oven cleaner, everything you could think of. It all worked OK, but I didnt want to spend the entire week fightning with all of this stuff. I went to the local automotive paint supply store, and picked up some stuff called something like "aircraft quality paint stripper". It in a black metal can and this stuff KICKS ASS!!! You brush it on and about 10 minutes later wipe it off with a damp rag and there you go. It will take a little longer for the stubborn spots, or depending on how thick its on, but it works ALOT quicker than anything I've tried. BUT BE CAREFUL!! Get some long rubber gloves to where, because as you brush it on, it kinda splatters back on your skin and IT BURNS!!! I did this in auto class back when I was in high school and went to my next class with little red spots/burns all over my arms. As soon as it hits your skin you feel it, but its worth it as good as this stuff works!! Good luck!
  12. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    Does it eat chrome? The little clasp where the pass. seat hooks up has undercoating all oveer it.
    Thanks,
    Greg Gayman
    Hawglet
    Stovie
    hawglet@excite.com
  13. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Sorry, I dont have an answer for that, I've never tried it on chrome.....
  14. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I got rid of it! I took to it with a needle scaler, and "gently persuaded" it to come off[​IMG] I tried gas, carb cleaner, lacquer thinner, synthol reducer, and acetone - all would soften it, but not to the point it would lift. I killed the scaler in the process, but for a $5 swap meet find, what do I expect?
  15. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    CONGRATS!! I remember now, the stuff I used was AVIATION PAINT REMOVER
  16. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Pugs, Eastwood makes a product specifically for the removal of undrercoating. I've never tried it but it is supposed to work pretty well. I've used paint stripper and it seemed to work pretty well along with a gasket scraper. I just haven't gotten around to finishing. Check out this link...
    <a target="_blank" href=http://www.eastwoodco.com/cgi-bin/sgsh0101.exe>http://www.eastwoodco.com/cgi-bin/sgsh0101.exe</a>
    "Constipated people don't give a crap!"
  17. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Hey Thanks! I'm going to get a couple of cans of that for when I get around to doing my fenderwells[​IMG]
