undercoating
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudRebel350, May 21, 2000.
  1. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    What is a good brand for undercoating? I want to help the rust problem before it gets worse. Its not bad but will get worse due to frequent "lets go muddin" trips. Anyway any help will be appreciated.
    J.D.
    88 Gmc Jimmy
  2. ScaryRide
    ScaryRide Newbie
    May 18, 2000
    3
    Really the brand isnt as important as the prep work before
    you undercoat......make sure you get everything as clean and dry as possible before it's sprayed this will keep you from trapping moisture under the rubberized caoting........
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
  4. mpikas
    mpikas Registered Member
    May 2, 2000
    15
    MD
    Try the 3m stuff in the blue can, I've used it for undercoating, sound deadening... It doesn't seem to flake off and be as messy as others.
