Undercoating
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArrowheadK5, Feb 28, 2002.
  1. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    What kind of undercoating will keep the frame from rusting?
    What is everyone using?
    "They couldn't hit an elephant at this dist..."
    - General John Sedgwick (1813-1864), last words
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Everyone here trusts POR15. You should put that not only to the frame, but to the entire underbody. Try <a target="_blank" href=http://www.por15.com>www.por15.com</a>
    Hey, nice Transformer under your name.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well POR works well but you need to sand down the frame to bare metal. Eastwood has some stuff for frames that is pretty good from what I have heard, but never used it. I would personally just hit any rust starting on the floor boards with it after grinding/sanding the worst stuff off. I did POR under my truck originally when I got it, to keep more damage from happening. I just got the floor fixed in a couple spots that were bad before I bought it and used Zerorust aerosal spray cans on the bare metal. Much cleaner then brush on IMO.
    Hit the rust areas with your choice of stuff...ZR, POR, etc. I nailed the under side areas that were painted and no rust with Restoleom gloss black... s coats and them used a cheapie $2-3 a can undercoating on decently thick. IMO remove any rust if possible... treat the area, and then layer, layer, layer. That's my $.02 worth oin dealing with MN salt
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  4. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    I am a child of the eighties and The Transformers will never die in my heart. It's Jazz, by the way. [​IMG]
