Underdrive Serpentine Pulleys
Discussion in 'The Garage' started by santana, Jan 21, 2005.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Who here runs these on their rigs?
    It's supposed to free up 15-20 HP at the rear wheels while slowing down the revs on all accessories with out affecting performance.
    What are the pros and cons of these?
    LMC has the set for under $100, Seems well worth it if you can pick up a bunch of ponies eh?..
    I'm considering going with these unless there are downsides to it.
  2. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Anyone? Bueler? Bueler?:confused:
  3. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    The only draw back I can think of would be with the alternator. If you are taxing the alt with things like off road lights and other accessories that draw a lot of juice, then under driving the alt may not be a good thing.
  4. Xtreme Off-Road
    Xtreme Off-Road Registered Member
    Apr 27, 2003
    48
    Ontario, Canada
    Don't forget about the power streering pump. I want as much help as it can give me when i'm trying to negotiate a trail. The bigger the tires are, the more you need the pump helping.
  5. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Already sounding like a bad idea.:blush:
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I run UD pulleys on my Mustang. They only seem to help a little at the top end. Dont believe the manufactures hype about them. Yur lucky to see 10 Hp gain on the top with UD pulleys. They really are ment for drag racing in a light car where you are trying to squeze every tenth you can out of your hot rod. The only reason I run them is I got a set for 25 bucks on E bay.
    I would not run them on a 4x4 truck. I really dont think they would help a heavy truck at all.
    Besides you would have probabally charging issues at low RPMs. like when crawling on the trail.
    Cant really run a powerful stereo, lights, or other heavy power robbers at low rpm. Also they put more strain on the battery.
    Doubt you would see any power gains on a heavy truck. Save your money and use it for something better. Like gas:D
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    we use them on the circle track car just cause they have deeper grooves and when the belt spins a little slower it is less likely to be thrown off(though it still happens when revving 7k for a while). I wouldn't run them on a daily driver or a trail rig. A street machine or drag racer I'd consider it.
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    a smaller pulley would reduce the current, not increase it. Same with pump flow, smaller pulley reduces flow.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    wrong. Smaller pulley on the alternator the alternator will spin faster. Faster = more power. Bigger pulley is the underdrive setup and that spins slower thus producing less power. Samething goes for the waterpump, smaller pulley faster it spins. Think ring and pinion. The pinion is the smaller gear and spins faster.
  10. Xtreme Off-Road
    Apr 27, 2003
    48
    Ontario, Canada
    I think he means the crank pulley. If you run a smaller crank pulley, all accessories will slow down.
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Smaller pulley on the alt should make it drive faster. Smaller pulley = less circumference = more turns per given length of belt gone round.
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah that is true but I'd just run a smaller alternator or power steering pulley. Wouldn't be surprised to lose power with a smaller pulley, less circumference=less leverage.
  13. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    *smacks self* yeh I dont know wtf i was thinking.
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    things get backwards in my head too, it sucks when you are so sure then you realize, damn I was way off.
  15. Ruthven13
    Ruthven13 1/2 ton status
    Mar 10, 2003
    664
    Fair Verona
    I had underdrives on my BBF in the old truck and didn't like them. Amps sucked at idle and the 40's were hard to turn at a stop on the trail. Only reason they were on there is they came with the truck and, being aluminum, looked cool!
