Underhood welder
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Dec 17, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Anybody got one? If so, details please.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, I don't have one, but there is one on my todo/wish list.
    Here are some links that may be usefull.
    http://www.pirate4x4.com/forum/showthread.php?s=54bf16a5cd6e45be7463b2691dbdccab&amp;threadid=7035&amp;highlight=dual+AND+alternator
    http://www.premierpowerwelder.com/index2.html
    I really like there ready welder too but $$$
    <a target="_blank" href=http://www.premierpowerwelder.com/readyweld/readyweld.html>http://www.premierpowerwelder.com/readyweld/readyweld.html</a>
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  3. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    Got a MobiWeld on my Blazer. Mounted the main box in the interior, on the floor hump where the manual trans shifter would come through the floor, as forward as I can (I'm running an auto).
    Like it a lot. But it's not cheap and it's a tool that you hope you won't have to use. But we have.
    --Rob
  4. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    I have a Ready Welder II and love it. I installed two batteries and can weld not only on my rig but can take out the batteries and go where ever I need to to weld on a rig whether it be 100' up the trail or I pull my rig next to somebody elses and weld. I have two 25' cables to make a total of 50' of welding cables. If I need farther than that is when I just pull the batteries and go with them to the spot needing welding. I gave $426 + tax for it.
    David
    <a target="_blank" href=http://www.extremeblazer.com>ExtremeBlazer</a>
