Underwater Repair
Discussion in 'The Garage' started by gunner_vincent, Jan 9, 2005.
  1. gunner_vincent
    gunner_vincent Registered Member
    Oct 17, 2004
    29
    Valdosta, GA
    hey guys I need some help... I sank my truck in the water.. up to the steering wheel. I got the truck going again, after days of draining/refill. The truck has developed sound, sound first like air escaping the collector gaskets. I changed the gaskets, and i am about to change the exhaust manifold gaskets... it sounds like it is coming from underneath the exhaust manifold gasket, now i am leaning towards rod or possible something in auto TH350 transmission...I give it gas, the sound gets louder. I would appreciate all inputs, I also posted this in 73-91 forum, i was told i should ask you guys.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    probably a rod knock. Get a good deal of water in the oil? please tell me you have changed the oil and tried to flush it out a little?
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if you sank it that far, did you change ALL of the fluids?
  4. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    hopefully he wasn't cranking with the cylinders full... i recently had a guy turn 2 rods into pretzels doing that....
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep hydraulic lock from having water in a cylinder is a great way t break or bend a rod or worse :D
    over the steering wheel is higher than manifolds and pipes, i hope you pulled spark plugs and cranked out water
    good luck
  6. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    i get a 1/2 dozen of those a year as a marine mechanic.. i'm pickling sunk and injested motors all the time....
  7. gunner_vincent
    Oct 17, 2004
    29
    Valdosta, GA
    sure did!
    I have changed all fluids now 4 times , from F/R diffs to tranny, to engine, power steering also pulled all covers and pans. The oil is now really clean! I did shut off the engine before It got deep, and I pulled the plugs and turned it over many times before reinstalling them (got plenty of water out :D ), even poured oil thru both valve covers with pan off just to pull water down, to help drain. I also changed exhaust manifold gaskets and collector gaskets (that may help on what it sounded like, escaping exhaust leak) I have all the interior out so everything echos inside, i put my jacket over the 4WD shifter hole, and i could not even hear it (it is that faint of a sound). Maybe i am just being paranoid, because i do not remeber hearing it beofe the titanic went down! I have pictures of the Blazer Bath but i cannot put them on the site, it keeps saying they are all too big, unless you guys know how to make them smaller, pretty cool pix... water to the top of steering wheel
  8. gunner_vincent
    Oct 17, 2004
    29
    Valdosta, GA
    Torque converter T/C
    Anybody heard of draining the T/C? If so How and where, and how do you fill it back up, thru transmission?:confused:
  9. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    There is a drain plug on the back of the 208/241..a pretty big bolt. You just fill it up till it starts coming out of that hole then put the plug back in. I'm not sure about the 203/205 cases.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think he meant torque converter. Chevy torque converters typically don't have drain plugs.
  11. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    If you think it is the tranny you can take the three tc bolts out and push the tc back as far as it will go and start it up and see if you still have the noise. No noise= something in the tranny.
