uneven front tire wear?
Discussion in 'The Garage' started by tykuhn, Nov 26, 2003.
  1. tykuhn
    tykuhn Newbie
    Nov 26, 2003
    Fernie,BC
    First post, my friend and I are wondering what to do if my tires are wearing on the inside? Possibly allignment, but what will it cost and what other thimgs could it be.I did a quick search but couldn't find the answer
  2. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    if its the inside of the tire it sounds like a camber or toe in issue. Get an alignment done (aroun d here they run me about $50) but be ready for em to tell you that you ball joints are gone.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I was just researching this today. Mine are wearing on the outside. What I found out was that you need offset ball joints. I guess im going to take my truck to a shop in Antioch, I have heard they know what there doing. Anyone else know what to do, or other shops? Thanks
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    also check the air pressure and make sure your not running to much. what tires do you run? i run 23psi in my 38in tsls and the tire wear is nice and even /forums/images/graemlins/thumb.gif
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have 38" Radials. The air pressure is even in all tires. I normally have them aired all the way up for driving around town, to school, etc. Im positive mine is a camber problem.
  6. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    wear basics
    Tire wear on center of tire = over pressure
    tire wear on both edges of tire =under pressure
    tire wear on outside of both tires = not enough tow
    tire wear on inside of both tires = to much toe
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    also check the air pressure and make sure your not running to much. what tires do you run? i run 23psi in my 38in tsls and the tire wear is nice, quick, and thank God, even /forums/images/graemlins/thumb.gif
    Fixed it for you. /forums/images/graemlins/thumb.gif
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    why do you say quick? i have almost 40,000 on my tsl's and still have about 30% tread left /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    I have 38" Radials. The air pressure is even in all tires. I normally have them aired all the way up for driving around town, to school, etc. I'm positive mine is a camber problem.
    yes it most likely is but just thought id mention the air pressure /forums/images/graemlins/thumb.gif
  10. 99firehawk
    Dec 15, 2002
    491
    "I have 38" Radials. The air pressure is even in all tires. I normally have them aired all the way up for driving around town, to school, etc. Im positive mine is a camber problem. "
    You can check your toe real easy in about 2 minutes for free. Get a tape measure and lay down in front of the truck place the end of the tape in to the tread about 13 inchs off the ground and 2-3 inchs from the inside edge. run the tape measure across to the other tire and measure at the EXACT same spot on the tread. Now write down your measurement, do the same thing on the back side of the front tires write down your measure ments, ideally you will want 1/16- 1/8 of toe in.
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Ok, I already know about where a tire wears and what the broblem is/could be. I also how to check the toe and it is fine. I guess i ll just go to that shop and see what they can do.
