Uneven tire wear....how do I fix it
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Mar 15, 2003.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    The rear is fine. On the front the outside of the tire has less tread, but the inside has a lot of tread. How do I go about fixing this? Thanks Mike
  2. Geno
    Geno Registered Member
    Nov 18, 2002
    52
    Dorchester, Nebraska.
    Mike, Make a visit to the alignment shop, they may have to shim your hubs, these shims go behind the spindle that your hub bearings ride on, this will set your caster/camber on your frontend. Needs to go on the machine to determine what size shims are needed. ;)
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Are they feathered as well? If they are it's probably just a toe-in problem. A 3/16" of toe-in on 235s looks like 10" on 38s.
    If they're not feathered then it's probably just a camber problem. Do the top of your tires tip outward? If so, it's a positive camber problem.
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    You generally cannot fix bad tread patterns once the wear has started. You need to correct your alignment and replace the bad tires when they are worn out.
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    feathered what is that? Thanks for the help Mike
  6. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    When you look at a lug and one part has more tread depth than the other part.
  7. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    the tread lugs take on a saw tooth effect
  8. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    wrap the worn down side with duck tape untill the other side catches up.... /forums/images/graemlins/thumb.gif
    j/k
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Either too much positive camber or too much toe in.
    Did you slam your tierod a while back? /forums/images/graemlins/grin.gif
    Check your balljoints too.
    Take it to an alignment shop to figure out what it is.
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    After I get my new tiers. I will be taking it to the shop. Thanks guys Mike
