Uneven tire wear questions **PICS ADDED**
Discussion in 'The Garage' started by 88K5Jimmy, Aug 26, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    The tires on the frontend of my K5 are wearing prematurely and I can't seem to figure out why. The passenger side tire is wearing prematurely on the outside and the driver side tire is wearing prematurely on the inside and outside of the tire. I am running 36x14.5x15 PJ's. The tire pressures are all the same at 18psi. I just replaced ball joints and draglink ends when I lifted it. I also recently had the front end aligned too. Seems to me that my camber is off, but I didn't think you had camber in a SFA??
    The only things I can think of are that the tires aren't on the specified rims (specified rim size 15x12), something is outta wack on the front end, or its just due to the width of the tires and the fact that the fronts turn and not the backs.
    Anybody have a clue?
    Ross
  2. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Re: Uneven tire wear questions
    18 psi
    from what i understand you shoulnt run under
    32 psi for street driving?
    someone with more info
    hopefully can help out,
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Well for the tire that is wearing out faseter on both outside efges, you have too low of psi in the tire. As for the other side, that can be part of it, as well as camber being off. They do make camber plates for our trucks.
    Dan
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Try more air pressure. Also the caster is probably out of whack with a 6" lift so the front axle probably needs to be shimmed. Mine was just on the edge of being in spec with 3" front springs.
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    18 psi
    The max psi on the sidewall is only 35 psi. I was running 25 psi but the centers were wearing out prematurely then.
    What do these consist of?
    How much would I need to shim?
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    The plate or shim goes inbetween the spindle and the knuckle. Get an alignment, find ou how far it is off, pull the spindle off, and put in the shim, and recheck.
    Dan
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i only run 20 psi on my tires.the max psi rating is rated at the max weight designated on the tire.most tires over 30 inches have a load rating of c meaning they are of heavier consistency to hold more weight.you get into 16.5 inch tires of any size and most are a d load rating to again hold more weight.our truck are not heavy enough to run the maximum alowable psi for the tire.you need to estimate how much weight is on the front and rear of the truck and adjust psi accordingly percentage wise to what the max weight would be and the max psi you would run for that weight.so if the maximum weight rating on the side of the tire is 50 psi at 4000 pounds,and your frontend of your truck weighs about 2000 pounds,you would want to run 25 psi in the tires to get a good tread pattern and even wear.i hope i didnt confuse anyone.i had to read it again twice to make sure i hadnt confused my self.lol /forums/images/graemlins/thumb.gif
  8. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Here are some pics.
    Driver front:
    Passenger front:
    Here is the driver rear to compare:
    As you can see on the driver front they are wearin on the outside especially, and on the inside. On the passenger side they are only wearing on the outside.
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Also the outside edges of tires wear out faster if you make alot of sharp turns, u-turns. etc. How often do you rotate your tires? You need to do it every 5000 miles or so.
    Dan
  10. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I haven't had these tires on even close to 3000 miles. I think something is wrong with the front axle, but don't know where to start.
  11. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    by the way, usually the maximum psi listed on the sidewall is for seating the beads....i couldnt even imagine why you would only run 18 psi on the street...id get the alignment checked out and have it fixed..
  12. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Just thought of something. Don't know if it means anything but, if I am indeed running too low a psi in the front tires, when I am turning could they be in a sense, "rolling under" and wearing specifically on the area mentioned?
  13. Confedneck
    Nov 1, 2002
    5,236
    no...but if your toe or camber/caster is out..then underinflation will only increase the tire wear issue...
  14. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Camber will make it wear on the outer edges.
    The factory spec for camber on a 88 is 1.5* +/- .75.
    Its a wide spec. IF the guys who did the alignment did it right, they would set it to 0 to +.5. Need to find out what its really set to. You may be able to call them and see if its on record.
  15. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Adjust tire pressure to tread wear pattern.
    Even left to right, although, it might require different pressures front to rear.
    Rapid RF shoulder tread wear is not unsual.
    People take Left-hand turns quicker than Right-hand turns.
    They also, brake longer and harder during a left-hand turns.
    Both conditions, wear the RF outer tread shoulders quicker.
    This is why, cross-rotateing tires is so important.
    Also, slightly less positive camber to the RF might help compensate.
    (Negative Camber is the way you "think" the tire should be, Positive Camber is how the tire actualy is, in this case)
  16. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    This is all great info guys. I really appreciate it. My plan right now is to get the alignment and everything checked again on the front end and then go from there.
    Anybody have any recommendations on what psi to run the front tires at? I'm thinking to start at 22 psi and see how that works.
