Unexplained cutting out
Discussion in 'The Garage' started by ChrisR750, Sep 28, 2006.
  1. ChrisR750
    ChrisR750 Registered Member
    Nov 21, 2005
    7
    Tampa, FL
    Hey guys, need a little help. I have a 1987 FI 350 that's been acting up lately. From time to time, the fuel gauge will peg past full, almost going all the way around to E again, and at the same time, there's no power, presumably from a loss of fuel to the motor. It happens intermittently, usually only for a second, sometimes more than once in a row, other times just once. Then, the truck goes back to running like a champ...it's almost like it stumbles, then is fine. I've had it in to my mechanic several times, and we have tried easy things like o2 sensor, switching cpu's...nothing's worked. I should mention that the needle on the fuel gauge does bounce because when gas was really expensive someone siphoned my tank and apparently did some damage. Whether this is related or not, I don't know. Any suggestions?
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    probly needs a new sender and pump.
  3. dyeager535
    26,979
    May need a new tank, they may have broken the plastic fuel well. If all this started up after the siphoning incident, I'd be suspecting the tank/sender components and something being loose now, if it's not consistent.
  4. southern customs k5
    southern customs k5 Newbie
    Sep 9, 2006
    4
    georgia
    check wiring for rat chews
  5. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I would suspect that when they siphoned the gas, they screwed up the sender/pump assembly...
