Unhappy new year - Smile, it can only get worse from here
Discussion in 'The Garage' started by MaxPF, Dec 31, 2006.
  1. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Well, when I was leaving work today I stopped to chat with a coworker for a few minutes. My truck was running during this time and he says "You have a puddle under your truck...". I get out and look - sure enough: There is a BIG greenish puddle :eek1:. I take it over to my buddy's house and check it out. The leak is coming from the head gasket area :( :doah:. So, now I am tearing the top end off my motor. Hopefully it is just a head gasket issue, but I have never seen this happen before. Usually a head gasket fails between a coolant passage and a cylinder. This leak is near where the coolant passages to the spark plug boss are located... and I have seen heads crack there :crazy: Man, I hope it is just a gasket issue that a pair of Fel-Pro perma-torque's will fix.
    One thing I was dismayed to find was coked oil in the rocker boxes :mad: There is also some dull orangish residue all over most of the rockers and pushrods. I've never seen that before, and I have seen the inside of a LOT of motors :dunno: The residue isn't rust - it rubs off with your fingers. Wierd. Obviously the PO didn't maintain the motor very well. It doesn't use any oil though...
    Anyways, cross your fingers for me. I can't really afford to build a new motor right now... :doah:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well , hope for the best . Don't worry too hard though , theres someone , somewhere , with a runner in your price range . I see em on craigslist all the time .
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Hey im doing the same thing now:D
    Got both heads off and just need some gaskets to slap it all together. I drained the oil today and for about 4 seconds was straight antifreeze:doah:
  4. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    man that sucks, mine burns oil really bad. i went through 3 quarts in about 100 miles of driving. it doesnt leak at all just eats it. i dont have any clue what is causing it either.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I hope you're ok man but I've just found similar deposits on my tear down and it was copper from the mains and ends!
  6. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    you prolly dont have ANY oil rings...:eek1: or it could be leaking from the valve seals realy realy badlly.
  7. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    i looked over my truck today as i havnt driven it in a couple weeks and although i dont have something as big as a leaking head gasket i found that i have a wheel cylinder that is leaking pretty bad and a leaking pinion seal. happy new year:rolleyes:
  8. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    This is strange. I pulled the offending cylinder head today and found... nothing :confused: I expected to see a leakage path on one side or other of the gasket, or on either the deck surface or the head, but I can't find anything. No visible cracks though, which is good. Still, I can't help feeling that I am missing something :( I am certain that the cooland was leaking from between the head and block - I saw it spewing out. So did my friend. Yet, there is no evidence of a leak or damaged/ruptured/blown gasket. Very strange...
    Anyway, I am going to pull the other head tomorrow, clean everything up, and check the surfaces for basic flatness with a straight edgr and a feeler gauge. If everything looks OK I will throw new gaskets on, screw it back together, and hope for the best. :crazy:
  9. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I drained the oil today and had the same thing :eek1: :doah:. Well, now the engine is hanging off of my cherry picker in the garage. I figured it would be easier to work on out of the truck, and it has oil leaks that need to be adressed. Unfortunately it looks like it is the origonal engine, which means it has nearly 200k on it. I really want to rip it apart and build a 383, but the $$$ isn't there... :(
  10. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Well, this sucks. So, I pulled my engine and stuck it on the engine stand:
    See the red-orange stuff in the coolant passages? Not good. :frown1: I pulled the drain plugs out of the block, and othing came out. There was sludge blocking the drain holes, again (I had already flushed a bunch out when I bought the truck) :mad:. I said f**K it and knocked all the freeze plugs out. What a mess:
    There was about an inch of orange sludge mixed with stop-leak in the bottom of both water jackets. It took me an hour to flush that crap out. No doubt the bottoms of the cylinder barrels were running very hot, especially the rear cylinders. Anyway, the water jackets are reasonably clean now. Hopefully it will run a bit cooler. After cleaning out the passages I dropped the pan, only to find an even more horrific sight :yikes: :
    That reddish brown over everything is a varnish like substance. Apparently, the PO didn't believe in oil changes anymore than he believed in flushing the coolant :angry1: . Here's a closer look:
    That substance isn't liquid or sticky, it is hard and brittle!!! What I think is that the poor coolant flow to the bottom of the cylinders caused the oil to get excessively hot. Combine that with not changing it routinely and this is what you get. Those main bearing bulkheads are right below the cylinders - I bet they were getting smoking hot. I'm surprised this motor hasn't lost a bearing...
    Anyway, I've got it partly cleaned up. I will finish the job tomorrow and bolt it back together, and hopefully stuff it back in in a couple days. A new motor has definitely moved up to the top of the list though :doah:
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you mix red & green coolant brown sludge can be a byproduct. The PO may have done that along with total neglect. It sucks when you find out that a PO just didn't care enough to do standard maintanence. I don't understand it but some people are a little off.
    Harley
  12. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    i had a ****ty new years too man dont worry
    but mine involves me, not my truck
    was sitting on a ledge 12 feet up, when this chick lunged at me, i lost my balance and fell on my back 12 FEET. fractured some ribs and a peice of my spine, but i can walk and talk
    just hurts to lift, move and cough
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    personally, i woudlnt mess with bolting it back together just yet. take the block and have it cleaned and checked for cracks. there's a reason that stop leak was in there, and it wasnt because the engine was keeping all of its coolant. :deal:
  14. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Not much choice. This truck is my DD, so I need to get it running ASAP. Besides, a new motor is in the works :D
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    ah... well, hopefully it doesnt leak too bad then.
  16. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    Just linked to this thread from my "just bought a K2500" from Oregon...
    So how's the sludge-bucket runnin'???
    My "Mix Match" '87 Sub 6.2 Banks was the same thing.... And the PO said he took care of it. They ALL say so... Haha.. Ug
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Gregs been driving the truck daily since he fixed it , and went wheeling a couple times too .
  18. uglytruk
    Oct 24, 2004
    1,329
    And his oil change frequency? Grin...
  19. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Once every 3k miles. The motor still doesn't burn any oil or have much blowby. The oil pressure at idle is a bit low (10psi at idle in the summer when using 10W30 :eek1:), but it runs great. When I get my diesel done and swapped in this motor will end up in a buggy :D
  20. uglytruk
    Oct 24, 2004
    1,329
    Funny how it should be toast, but runs gr8!
    My '83 POS is also beat ta ****, but has lots left. Overheated several times. Manifolds glowing cherry red with out any oil! NOTHING!!! It all pumped out the front seal when I was cruising at 80mph in O/drive.
    I still plow with it, but I noticed a wrist pin rap today....
