Unhappy w/dissconnects *DELETED*
Discussion in 'OffRoad Design' started by 84k5, Jan 13, 2001.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Post deleted by 84k5
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
  4. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Re: Unhappy w/dissconnects
    There supposed to be very tight. You would'nt want any play in it would you. I carried a hammer with me and tapped them in and out. The jeep guys do the same thing.
    79 Blazer 6"lift 35's locked/4:56 <A target="_blank" HREF=http://www.keith.coloradok5.com>http://www.keith.coloradok5.com</A>
  5. Re: Unhappy w/dissconnects
    Mine and others I know that run them work just fine... realize that disconnecting the sway bar is not a 'normal' function of the vehicle. A 'normal' function would be using the windshield wipers when it starts to rain, quick and easy. Disconnecting the sway bar should be planned in advance, before a big wheeling weekend (not just hitting a little mud on the way home from work). The sway bar prevents the vehicle from swaying... play in the disconnects would cause sway and eat the bushings in no time. The only way for these to fit is TIGHT!!!! I have greased mine and loosened the bolts that hold the sway bar to the frame and still have to use a crowbar and a hammer to get the pins out and move the bay up (WELL WORTH IT!!!). If you were thinking that these were like the 'quick' disconnects for a jeep, they are not... they are WAY better then those!!! I wheel with some jeeps... (sorry, company down here is slim to none....) and they don't even use their disconnects because they are such a pain to put back on. DON'T SEND YOURS BACK, just practice using them a little (it gets easier). Always make sure you are on level ground when disconnecting and reconnecting the sway bar. Good Luck!!
    Jeff
  6. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
  7. tRustyK5
    Jul 23, 2000
    36,185
    1,393
    E-town baby!
    Post deleted by tRustyK5
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Great I'll buy it off you, or just give it to me......How about $25?
    <font color=green> No machines are perfect!</font color=green>
  9. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    I'm not what's going on with this post, does anyone have copies of the originals? I'm interested in hearing the bad news too, then sort out the problems from the bs. I'm not sure how this all read, but if it was deleted, it was probably profane I would guess. Anybody know the gist of the conversation?
    SW-ORD
  10. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Just that the dico's needed a hammer to undo and then link back up. I think the guy wanted to be able to do it with on hand and in 30 seconds. also, no one mentioned that the dico's allowed the sway bar to even be used, most of the time you can't get hooked back up after a lift is put in.
  11. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I can sum it up for the most part. 84k5thought there was something wrong with his disconnects since the pins were so hard to get out. He finally got them out, but the bushing popped out, and he had some trouble getting it back in. He thought the pin was going to be very easy to pull out, I received mine yesterday along with my steering box brace, and the pin on the disconnects is hard to get in and out. 84K5 did want to send them back, but he figured out that in order for the swaybar to serve its purpose it needed to be in there tight. I think everything is Ok now.
    Dawson
    88 K5
  12. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have the disconnects on simply because they allowed me to use my sway bar with my 6" lift. Without the disconnects, the sway bar was on there loosely (only way I could get it on) and way basically dead weight.
    I have actually never disconnected the sway bar except to test it. But it's good to know I can if I need to.
    It would be a pain if you disconnected and reconnected it every day, but if you did, just carry a BFH and some gloves.
    -- Mike
