unknown spring driver seat
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by roadrash, Oct 4, 2002.
  1. roadrash
    roadrash Registered Member
    Oct 4, 2002
    10
    georgia
    I have a 71 Blazer that has a spring contraption behind the driver's seat on the vertical portion of the step going into the rear seat area. Any ideas of what it is? Don't know if it is stock or not. The spring has a handle on one side and attaches to the step on the other side.
  2. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    I asked the same question a while ago. From the responses I got it is a jack mount.
  3. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Have you got a picture of this "spring thing"?
    I'm curious to see what it is that you're describing..... /forums/images/graemlins/crazy.gif
  4. roadrash
    Oct 4, 2002
    10
    georgia
    I don't have a picture of the spring. It is right behind the drivers seat on the vertical portion of the step. It is about 20"long and about 3/4" in diameter. At one end there is a bracket that is bolted into the step which secures one end of the spring and about midway down there is hook shaped bracket that prevents the spring from rattling against the step. At the other end of the spring next to the driver's door, the spring has a "T" handle on the end which you hook on to another bracket attached to the vertical portion of the step. There isn't much room behind he drivers seat and the step, so I don't know what you could put in that space. It might just be some weird contraption that previous owner installed.
  5. Roostr84
    Aug 19, 2000
    451
    NJ
    It is something the previous owner installed. I have the same piece. Like I said I was told by the guys on the 67-72 chevy trucks board it was for a jack. I looked for the post but I guess they no longer have it in their database. I will try to post a pic of mine if I can get a camera.
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i think i have one too,but dont know whats it for though,sorry /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
  7. J.Lance
    J.Lance 1/2 ton status
    Oct 8, 2002
    145
    Arvada, CO
    It is the factory installed spring to hold a bottle jack and tire iron. My factory assembly manual actually has directions on how to mount the jack using this spring. Trucks have a similar spring mounted underneath the bench seat. I removed the spring from my old '72 /forums/images/graemlins/k5.gif when I installed a new carpet kit, couldn't for the life of me think of a good use for it!
  8. roadrash
    Oct 4, 2002
    10
    georgia
    Thanks for the answer. Maybe my rear passengers can use it to hold a "cold one"
