UPDATE**87 K5 Cuts Off Driving / Idling **UPDATE
Discussion in 'The Garage' started by mypitcrew, Apr 22, 2006.
  1. mypitcrew
    mypitcrew Newbie
    Apr 22, 2006
    N. VA
    :smile1: 87 K5 Blazer.... WAS THE FUEL INJECTOR Thank You All
  2. KingDuramax
    KingDuramax 1/2 ton status
    Jan 17, 2006
    451
    NY 14701
    A tuneup cant hurt. If that dosen't fix the problem rebuild the distributor. The bushings wear out and cause them to stall at stops and idle.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Change the pick-up coil. Mine was doing the same thing......I also had to change the main shaft int he distro as it was no longer firing the pick-up through the reluctor wheel. Not very common though.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Have you Checked for trouble codes?
    If there are none. Then try replacing the distributor module first.
    Your problems are pretty common indicator of a bad module.
    A bad pick up coil will usually throw a code 42.
    If you dont know how to check for trouble codes go here:http://www.troublecodes.net/GM/
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Mine was doing this "cutting out" thing a little while back, and i did the changing of a bunch of parts,, thought i had fixed it until it wouldn't start one morning,,,ended up being a bad injector.
  6. readymix
    May 30, 2004
    6,706
    26
    I never got any codes with mine.
    The neighbor did get a 42 but his reluctor wheel was missing one of the tongs..
  7. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I think blottozone might test the module for free (but don't quote me on that).
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    never received any codes from mine either, would be driving down the road, and it was almost like you would turn the key off real quick, and then turn it back on, the engine would literally just shut off for about 2-3 seconds, and then get going again.
    no codes, no lights.
    $150 for a new fuel injector from Napa,,,because Autozones was a serious P.O.S. and it's been running great ever since.
  9. mypitcrew
    mypitcrew Newbie
    Apr 22, 2006
    N. VA
    Was the fuel injector.....Thank You all
  10. KingDuramax
    Jan 17, 2006
    451
    NY 14701
    Glad to hear your back on the road.
