Update build of my 73 J##p J-4000 FSJ (lot of pics)
Discussion in 'The Garage' started by RampageFSJ, Dec 6, 2006.
  1. RampageFSJ
    RampageFSJ 1/2 ton status
    Aug 18, 2005
    121
    Ulysses KS
    I haven't been on here that much lately except to ask a few questions for friends (thank you for all the help), I thought that I would post up the build of my J-4000 to make up for my time missing, because it looked like there were a few people interested in it when I introduced it here. I hope you like it (and don't kick me off because it's not GM:o )
    Specs- 1973 Jeep J-4000, AMC 360, TH400, Quadra trac, Dodge dana 61 front (open), van width 14 bolt rear (lincoln locked), Chevy 56" rear springs mounted under the frame in the rear, 74 J-10 leaves mounted under the frame with longer shackles in the front, with a total of around 10" of lift, 39.5" Swamper TSL's.
    Here's the (kinda) finished product at a car show. Build stages to come.
  2. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    I started taking pics with a digital camera after the rear suspension was done.
    I then loosely threw the bed on, pulled the drivetrain, and mocked up the front suspension with a 10 bolt. The rear axle at the time was a SRW 14 bolt for mock up.
  3. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    I then took it to the school, welded up the front suspension, cleaned and painted the frame, installed the drivetrain, and wired the new front clip with the fender flares removed.
    I then moved on to work on the van 14 bolt.
    New perches from Ruff Stuff Specialties.
    Shaved the plow off.
    Cleaned and painted.
  4. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    The bed went on for the final time.
    Rear flares came off.
  5. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    very nice build up!
    keep the pictures coming!
  6. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    Wheel spacers added.
    Then the 39.5's went on.
    Then we dragged it up the RTI ramp with my brother's truck for a flex test.
    For reference, I'm 6' 1" in this next pic.
  7. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    I changed out the gears in the rear, with welded spiders. The ones I have now are 4:10s because that is the lowest that the D61 front can take without a spacer. I fitted a rear shaft and a front one, but I didn't get the front gears changed out in time for a car crush at a local car show, so I did my crushing in 2wd.
  8. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    A friend's chevy shortbed K-10 went first. I know you'll want specs, so it's a 75 with a 350, th350, np205, 14 bolt rear with a limited slip, dana 44 front (open), 4:10 gears, 4" lift as I have been told with plenty of trimming, 35x16 boggers on 15x12 eight lug steelies.
    Then I went.
    Then my brother's cj-5
    Then we went again.
  9. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    looks good.always liked the older jeep trucks. are you different heights in different pics?
  10. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    The major casualties.
    They did strike back though.
    Later in the day, we went for a try in a T-bone fashion, every rig broke / damaged something.
    The chevy bent his tierod, broke his rear bumper off coming down off of the cars, and leaked some tranny fluid. But he was the only one to make it over.
    I locked it into 4wd, because I was slipping enough to not really hurt much. I busted my front shaft trying to hop the rear tires up. I removed it and drove home.
    The CJ failed after several flying attempts, tore off most of the exhaust.
    Here's my busted shaft. It seems that it snapped from being too brittle from the shop. My brother and I replaced it with a much better solution.
    More later.
  11. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    personally i love the old jeeps. Nice old rig.
  12. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I like the full size jeeps, you dont see them every day!
  13. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    Thanks for the compliments. I changed out the front gears, then took it out to test a couple of times in a pasture and in a dirt filled lot. That's where I am today, just taking care of little problems as they pop up.
  14. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
  15. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I like the fact you were in median strip crushing cars:haha: :haha: . Some guy went to get gas down the road and came back to find you guys smushing up his car:haha: :haha: .
  16. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    :eek::eek::crazy::eek1::eek1:
    I cannot believe that you are running shackles in the front! I bet that think creeps forward at brakeing.
    Also- What size tires are you running? Otherwise looks great. We have one of those jeeps laying around.
  17. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    looks sweet, whatcha gonna paint it? i think you should put
    "aint no barbie heep" on the windshield
  18. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    Which pics? I never changed the height, only the tires.
    Sorry, I have to go, I'll answer more later.
  19. Smokin'Joe
    Smokin'Joe Registered Member
    Jul 27, 2006
    50
    Butler,Pa
    Having grown up with Wagoneers, Cherokees, and a couple J-10's, I've gotta say that is sweet. "... with bald tires, that old Wagoneer would go places this Bronco can't." said by the PO of one my dad had bought. I prefer my Chevys, but am still fond of them old fullsize heeps.
  20. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    Actually, that is on the side of the highway. Coincidently, there was an accident at the intersection just down the road from us, but from the angle of impact, we didn't cause it with a distraction.
    It is kinda hard to stop, but I guess that's to be expected with 100 or so pounds of tires on each corner. I chose them in the front, because it pushes the front tire into obstacles when driving.
    The tires are 39.5" tsl's.
    When I get the chance, I'm going to paint it rattle can flat black.
