*Update* D60 King pin spring
Discussion in 'The Garage' started by FWP, Jul 3, 2002.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Working on rebuilding a 60 and it looks like the upper springs are bent??
    Does anybody have any new ones that they can put a caliper on and give me the unloaded spring length?
  2. spaceboy
    spaceboy 1/2 ton status
    Jan 14, 2002
    106
    Pearl City, Hawaii
    Re: D60 King pin spring
    I got a dana 60 king pin rebuild kit if you want it. It's brand new.
  3. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Fred, I just checked a brand new one and it measures 2.150"
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thanks Bill /forums/images/icons/smile.gif . Mine measure from 2.150 to 2.250, depending on which part of the spring you measure it on. If I stand the springs on end, it looks like they tilt to one side. The flat side of the springs aren't parallel. I wonder if that's normal /forums/images/icons/confused.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Fred, I don't have any bare springs laying around, so can't help you here. /forums/images/icons/frown.gif
    BTW, could you take some pics and post them up of the brackets that Dan fabbed/welded to the D60 knuckles to show everybody how he did this to make the D44/10 bolt calipers work? I wanna see some pics of this again, but not the pics Dan took. I wanna see some good pics of the whole bearing hub, knuckle, etc. /forums/images/icons/wink.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the nylon cone has an indent that the springs tail sits in leveling it out IIRC
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Sure, I can do that. Give me a week or so. I thought about doing some kind of write up, but since I didn't actually do the work, I thought it would be cheating. The rotors are 3/4 ton rotors, not 1/2 ton. The D60 backing plate has the 3/8 thick tabs welded on (pro welding job BTW, not hacked), and the knuckles are untouched, as are the hubs. I don't have a digi cam, just a scanner, so the pics may not be the best quality.
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The model I have (79) uses a spring retainer that seats between the spring and bushing. The bushing is flat and the retainer is flat, except in the center, to locate the spring....
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Whether you did the work or not, the info could be usefull. I say write it up if you have time and the urge...
    I don't have the retainer, but the bushing is also flat. I don't recall the spring having any bend to it at all, just sat flat, IIRC. Also, on the Avalanche arms, there is a flat aluminum spacer that sets on the bushing, spring on the spacer, and then the cap.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you are correct i misspoke
    when i was mocking it up last time I had forgotten the sheet metal that protects the nylon from the spring and that was what i was recalling /forums/images/icons/confused.gif
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Interesting discovery, Just measured 2 brand new GM springs, right out of the package. 2.282-2.287, all the way around on the flats. The springs are straight also. Thats .030-.050" longer than my definitely worn out ones.
    One possible death wobble cure???
  12. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Fred, The measurement that I gave you earlier in the post was also a brand new one that I actually tore open the bag to measure. Goes to show how much variation they have in their Quality Control or lack of Quality Control.
  13. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I wonder if it's the heat up here making it longer /forums/images/icons/laugh.gif . Yeah that doesn't sound quite right. I wonder what the heck is up, I wonder what, if any, spec they have on that particular part.
    BTW, the part number I got was 462799, Same as yours?
    Thanks again for checking. That's what's cool about the good folks here, They will head out to the garage, even if it's inconvenient, to check on stuff for other members. /forums/images/icons/cool.gif
  14. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    Fred, I tossed the bag after opening it and its in the dumpster under the days chips and turnings. I need to pick up another spring anyway, I'll measure it also and post the length.
