UPDATE...electric fans
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JoshA, May 31, 2002.
  1. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    I had a post up a few days ago asking about electric fans. I got a set up installed yesterday and it works great. the best part is that I did it much cheaper than I thought I would.
    I got duel fans from a '94 camaro (V8) for $45. they came with the shroud/mounting piece and the wires.
    I was able to find a electric fan controller for $20 at pep boys. the kit included the temp probe, relay, wires and very good instructions (really quite simple). the kit will run duel fans and has a separate wire for hooking up a toggle switch or A/C switch.
    the fans and shroud are almost a perfect fit to my radiator and I simply mounted them directly to it with mounting straps I got from a radiator shop for $5.
    with various wire connectors and everything I am into this about $75 and it works great. the temp here was low 90's yesterday and I had no problems.
  2. Burt4x4
    Burt4x4 3/4 ton status
    California (Modesto area)
    Good Job too!!
