--UPDATE-- FIGURED IT OUT!!! Do these pictures of my 205 look right???
Discussion in 'The Garage' started by dawson444, Jan 24, 2004.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    !!!Sorry for the massive pictures, I am not sure of how to resize them!!!
    Is the big gap that is between the two gear selection gears there suppose to be there? (I know the shift fork is missing). My 205 doesn't want to completely engage the single gear on the other side of the gap (input side). From the pictures and diagrams I have found it appears like the shift fork was installed the correct way. Although, I have not tried it, it also seems like if I install it the other way, it would give the shift fork the little bit of extra travel it needs to engage. Can anyone shed some light on this?
    Anyone see anything wrong with any of the picures (besides the dirty garage)? Thanks!
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Re: Do these pictures of my 205 look right??? (Warning: VERY large pictures!!!)
    Gears seem to look o.k /forums/images/graemlins/thumb.gif
  3. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    What about the gap between the set of 4 gears and the single gear on the input side, is that suppose to be there?
  4. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    A littlle disclaimer frist. It has been ten years sence I put a 205 together. Now on to the problem, I don't think there is suppose to be that big of gap between the input gear and output shaft. Check the needle bearing inside the output shaft to see if any have fallen down or anything that is preventing the input gear going deeper into the output shaft.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what he said.
  6. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    I figured out what it was. The input bearing was sticking too far out on the case. A few taps w/ the rubber mallet, and all was good to go.
    Now if I could just get my twin stick mod to work, it keeps messing up, I can get the rear in high and the front in low, and it is pissing me off! Thanks for the help!
