*UPDATE* major engine trouble *UPDATE*
Discussion in 'The Garage' started by adamforsythe, Aug 14, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Well the 350 is in the shop. When I was driving by the shop I heard a bang it sounded like a back fire and the truck started to tick. It starts up it idles fine but there is a ticking sound coming from what I believe is the 5th cylinder. When the engine is under load if you put any kind of force on the gas the truck will back fire and tick pretty bad.
    What do you guys think it is? There are around 15,000 miles on the engine.
    *-------UPDATE*--------UPDATE*---------*UPDATE*-------*UPDATE-----*
    Hello,
    I got the truck back from the shop today. TWO bolts on my intake where way to long and hitting the pushrods. That ended up bending those two rods and you guys know what happens after that. It only cost me $20.00 for him to do the work and play with the other valves. No more ticking, the engine runs like a beast.
    Adam
  2. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    sounds like a prob in the exhaust valve to me... failed retainer, sucked in valve, etc...
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    That is kinda what I was thinking.
    Adam
  4. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    sprung spring??
    Might have broken a valve spring ?? definately sounds valve related,especially if its ticking and backfiring..or a bad plug wire arcing to ground???... :crazy:
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I am hoping that it is the valve spring. What would case no oil coming up through the pushrod? I did noticed that on one of my pushrods on my number 5 cylinder.
    Adam
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    collapsed/broken lifter???
  7. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    update .....first post
