UPDATE !!!!! Need help FAST
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Oct 22, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    OK I took the cover off and good news nothing was wrong with it. then I looked at the u joints again the back one closest to the rear was broke. I thought that they would of been ok sincce i thought I had replaced them both already about 6 months ago. But I was wrong the front one was replcaed. I asked a mechanic about it he said since the front one was replaced it threw the rear one off balance or something and thats why it broke but I think it just broke because of natural wear and tear. So too make a long sotry short by me taking a look at it myself it saved me allot of money. Thanks for the help everyone.
    /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gifMy rear end is making clunking noises when I shift into drive. ANd it is not the u joints I just replaced those not too long ago. My dad said that when he looked under there the bearing cap was moving in and out with the drive shaft but just a little he said. He said my rear end migth be going out. How can you tell if it is going out and what happens when it does go out? It is a 10 bolt stock. And if at all possible if anyone in here knows where I can get this fixed at in or around the tacoma washington ar /forums/images/graemlins/usaflag.gifea I would appreciate finding out. I hope I can get this fixed Im suppose to go to boise for a week next monday then go to California after that.
  2. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    Re: Need help FAST
    i had less than 5 months on my u joints auto zone crap had the classic clunk also had some noise from the ring and pinion so /forums/images/graemlins/usaflag.gifi did a complete rebuild also changed the u joints the old ones were shot ???? get the spicer joints put them in and go from there /forums/images/graemlins/thumb.gif
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    Re: Need help FAST
    pop the diff cover off and look for broken teeth, and check for excessive play in the gears. a fluid change cant hurt and youll get a good look at the gears
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  4. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Re: Need help FAST
    How much woudl all that cost me?
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: Need help FAST
    Take the cover off and take a look inside and see if you see anything.
  6. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Re: Need help FAST
    I have play in my slip yoke, check there and around there and the things that hold the u-joint bearing caps.
  7. dyeager535
    26,979
    Re: Need help FAST
    Are you in Tacoma now? I know there are a couple of listers around, but if you are in Tacoma, and can't get any help there, swing up this way and we can probably check it out, at least take a good look at stuff.
    Tomorrows my last night in town, but I've got a flat driveway....
  8. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Re: Need help FAST
    Ya, dude where are you at? If your in Tacoma your like an hour away from me. I, er we can get that gear set-up done here if need be. In a pinch I have tons of stuff here.
  9. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Re: Need help FAST
    Yeah Im in tacoma now well actually gig harbor but its close enough. Im gonna take the cover off tommorow and take a look around first I guess Ill go form there. if you want to pm me your numbers Ill give you a call after I get done with it tommorow. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/rolleyes.gif
  10. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Re: Need help FAST
    plan it. /forums/images/graemlins/grin.gif
  11. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Re: Need help FAST
    sent it dude. /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif
  12. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Re: Need help FAST
    WELL SH!T I took my truck to a couple different places in town and they all said yep your rear end is screwed. One place wants $695 to fix it another wants between $750-$900 to fix it and then I guess just for kicks I went to the chevy dealer they want 576 for the labor and 1000 for the parts.
    Does anyone know of a cheaper place in the seattle tacoma area to get this doen at. I would do it myself if i knew how and had the tools to do it. But /forums/images/graemlins/mad.gif dont.
  13. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Re: Need help FAST
    if its screwed up why not just go to a yard and look for another axle? you might even find a better gear ratio or upgrade to a 14ff if you want. it would be alot cheaper.
  14. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Re: Need help FAST
    Well is that easier and cheaper to do then have someone rebuild one for me? Also if I do go to a junk yard how can I tell if its a good one or not? And how much do you think I should spend for a used one?
    If you think I should get one form a junk yard and if you know where a junk yard is around the seattle tacoma area let me know.
    Brian
  15. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Re: Need help FAST
    OK, so Its messed up, what is? Is the ring gear broken? the pinion? or is the carrier? I think maybe you need to take the cover off and see for yourself what is broken. You maybe able to just do spider gears and bo done with it. /forums/images/graemlins/grin.gif (about 150 bucks) or you may need a full rebuild. You won't know anything till you get that cover off. I can get all the parts for cheeper, usually than you would pay so.............
  16. dyeager535
    26,979
    Re: Need help FAST
    Your are close to Aaron, why don't you take it over to Aaron's?? Of course your gonna take it in the butt if you have a shop do the work! You also know he has nothing to gain by helping you, and it *probably* won't cost you anything. :P
    You will get hosedat most yards around here too, front 10 bolts run $400, rears are at least $200.
  17. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
  18. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Well that is very good news! /forums/images/graemlins/grin.gif
    Even better than that you didn't loose the driveline while driving! /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
