UPDATE!!!New Truck With PICS !!!!!
Discussion in 'The Garage' started by mudslinger99, May 3, 2005.
  1. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    PICS ON 2ND PAGE Thanks to Readymix for putting the pics up ...Any how the specs are as follows
    84 k 20
    350sb
    400 turbo
    208
    33 12.50 16.5
    14 bolt FF rear
    stock front Dana 44 10 bolt
    4:10 front and back
    roll bar with 4 Kc lights
    push bar 2 lights unknown
    as of today all new 4 core radiator,front axle bearings and Warn locking hubs
    future plans lift,tires and paint then who knows :grin:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    If you e-mail them to me in the next few minutes i will post them
    readymix @ sbcglobal.net
    remove the spaces
  3. mudslinger99
    Oct 8, 2004
    512
    East Coast
    E-MAIL sent thanks for the help with the pics...I hope i got them to you in time if not tomorrow will be fine thanks again
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  5. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    if its a stock k20 the front axel should not be a dana 60... ;)
  6. blacksheep10
    blacksheep10 Registered Member
    Feb 16, 2005
    37
    Paola, KS
    Na, Fords got 60 rears. Chevys got 14 rears (unless it is a fleetside with a 70). Count the bolts on the cover. That year will be a SF14
  7. readymix
    May 30, 2004
    6,706
    26
    I am at work now so i will post them when i get home
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    there are '84 3/4ton 14Bolt FF's too...
  9. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    He was talking about the front axle, not the rear........
    I have a 83 3/4 with a 14 bff........ :D
  10. mudslinger99
    Oct 8, 2004
    512
    East Coast
    Readymix= Thanks for the help
    Divorced= Thanks for the links im still learning this pic posting stuff :laugh:
    Steve_Kibb= I was not talking about the front axle... Quote ''suppose to be a Dana 60 14 bolt rear ?''
    It does has 14 bolts in the cover as you will see in the pics that i sent Readymix.. But it is not a stock ''Rear'' it has been changed.. Thanks for the replys
  11. readymix
    May 30, 2004
    6,706
    26
  12. mudslinger99
    Oct 8, 2004
    512
    East Coast
    Thanks Readymix for taking the time to put them up for me :D ..
    Ok now for the questions.. What rear would you say that 14 bolt is ? The front springs are almost completly flat is that normal ? What would you guess a truck like that would be worth in your area ? Keep in mind the truck runs perfect and everything on it works..
  13. readymix
    May 30, 2004
    6,706
    26
    rear axle = 14 FF
    Front springs being flat is normal if no lift in installed. Most stockers have a negative arch to them.
    No idea on what it would be worth
  14. mudslinger99
    Oct 8, 2004
    512
    East Coast
    DAM !!!! 425 views and no replys to the pics ?? No questions or comments ?? I figured somebody would have something to say...
    I mean come on fellows tell me what you think good or bad i can take it :laugh: :laugh: .....
  15. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well I can tell you that the body is definately in better shape than mine is.... note to self "work on body".
  16. mudslinger99
    Oct 8, 2004
    512
    East Coast
    Yeah considering that it is a 21 year old truck that is mostly all original I think it is pretty good.... For the most part it seems to be pretty solid other than the rocker panels which is normal... The fellow i got it from sanded it down to paint it but he races drag cars and needed it to tow his car and trailer to the track.. So he just shot some primer on it and drove it... Then he bought a new tow rig and decided to sell it to me ... :D :D As soon as i get some time I'm going to cut out and replace the rockers and finish what he started... I'm not sure what color to paint it yet though.... My father in-law has some blue paint so I'm thinking FREEBIE :saweet: :saweet:
  17. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    IMHO, looks like that truck has some lift to it. The springs on a 2.5 inch lift are just about flat, stock have a negative arc as stated before.
    Truck looks good :D
    Definately a 14bff out back :thumb:
    When I baught my truck in SC a few years ago, I gave $3000 for it, was a 3/4 ton 4x4 6.2 diesel with the 465 tranny. Bed wasn't in as good condition as yours. They are tough trucks, and will flex pretty good, 56 inch rear springs :D
  18. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    ps, front axle is a 10 bolt, unless its been swapped out :D
  19. mudslinger99
    Oct 8, 2004
    512
    East Coast
    Good eye Steve i think you are correct... After crawling around underneath a few minutes it does have 2inch blocks in the rear... The front is a 10 bolt Dana 44.... The rear springs are 56inch and the front is 48inch... Thanks for the reply..
