Update on my blazer project.......
Discussion in 'Pacific Region' started by Silver84k5, Nov 4, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i have ditched the 8 inch springs, in favor of stock rear springs with a 0 rate and a shackle flip, and the front now has 4 inch springs with a 0 rate (dana 60 spring perches add an inch) then goes on the one inch body lift, so i will finally be able to flex, and not have to slow down to 2 miles and hour to go over speed bumps. Only real screw up that i made this time around was... I had to pull the gas tank to put on the shackle flip, well tonight i was in the mood to get some more work done so i get the rear leafs in and bolt the axle back then i decide to put the gas tank back in, Then after i get it in there, i Realize i have to pull it back out again to put the 1 inch body on, at that point i said the hell with it and called it a night....
  2. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    Well, at least you got a little work out. /forums/images/graemlins/smile.gif instead of going to the gym you saved money by doing it in your garage.
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    pretty much all my working out is done under my truck, hey By the way, im getting a Digi camera, i wish i could took pics of my entire build up from start to finish, but too late can i just snap some shots, and write a story. would you put it up on your site?
  4. ChevyHuny
    Aug 17, 2001
    2,279
    Washington State
    Absolutly /forums/images/graemlins/smile.gif Its ok if you do not have all of the pictures. Just send what you do want up and the story to Mandy@MandyDyer.com when you are ready.
    You have come a long way with it in the last year.
