update on refurbishing my center console(PIC\'S)**UPDATED WITH MORE PIC\'S**
Discussion in 'The Garage' started by BobK, Jan 21, 2003.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    About 2 months ago I asked for tips on refurbishing my center console from my 71 Blazer.I took the suggestions given and went to work(I'm a slow worker) :grin:
    Here are the results.I think it turned out AWESOME!!!!
    Thanks to those who gave tips.
    Before
    After
    To see all the pic's I took while redoing the console click HERE
  2. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    Re: update on refurbishing my center console(PIC\'S)
    Impressive. Looks real nice.
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    looks good /forums/images/graemlins/thumb.gif
  4. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Looks good. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif It is always cool when you do it yourself and save $$$$ /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    kicka$$ job on the console.it looks new.mine never came with one.it doesnt even have holes for one.i always wondered,does it have welded bolts on the undeside of the cody or does it bolt with a locknut on the backside of the body?thanx and good job
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    From what I can tell...the console attaches to the floor using simple screws (no backing plates of re-inforcements) in the floor.
    Not really the greatest mounting system, but it was cheap. I think when I re-do consoles and floor area, I might graft-in some thicker plating into that area of the floor, so I can actually drill-and-tap some stronger holes and use machine screws instead of sheetmetal screws....
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Bob,
    REALLY NICE! /forums/images/graemlins/thumb.gif
    I have a couple of consoles in my garage that I've yet to start "restoring"....one is the square hole seatbelt holder one, and the other is the round cupholder one. I still can't decide if I prefer "100% original" or "cupholder functional"....I guess having both means I don't have to choose...!!! /forums/images/graemlins/grin.gif
    A question for BobK or anyone:
    When doing repairs on a "textured" surface like these consoles, do you have any idea how to reproduce the texture in the patched areas? That is one of the things that's been holding me back on mine. I'd really like to know how that part of the restoration is done.
  8. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    im looking at getting a tuffy console and that is the same thing i will prob ably do.that way noone can get into it unless they bust the top off or rip out the floor of my truck.reinforced at least it will not strip out the holes in the floor
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    very nice job /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Nice job. /forums/images/graemlins/thumb.gif
    This is the kind of thing that might be nice in a tech article.
  11. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    What Greg said about the floor,it's just screwed in.I think I'm going to weld 4 bolts to the underside of the truck so I can just bolt it in.
    As far as the texureing goes Greg.
    Lay a piece of plastic wrap(Saran wrap or whatever) over a texured area of the console.Then apply what-ever compound you wish.Like plaster,J.B. weld or some type of a semi-liquid compund that hardens and will conform to the texure of the console.The plastic wrap will prevent it from sticking and you'd be able to peel the new texured template right off.
    The areas I fixed were not worth the effort to me.But say you had a hole in the side or something like that,I think it would work great. /forums/images/graemlins/grin.gif
  12. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Are you guys having to "sign up" to Image Station to view the rest of the pic's?
    If so I'll just post the here.
    Let me know.
  13. Kyle89K5
    2,273
    OKLAHOMA
    Yep, not a big deal, but it does ask for you to register.
    KP
  14. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    O.k. I'll post some pic's here.
    The bottom had a hole and a major crack that went the length of the base of the console.
    This is where the lid sits on.This cross piece was busted in half.I used J.B. Weld to fix all the cracks in the console.I bent up some 3/4" aluminium and rivitted it in place to help support this area.
    Here the lid has been stripped to the orig. finish and is ready for paint.
    I used 26 Gauge galvinized sheet metal to make plates for the bottom and the inside bottom.It covers the hole and will help to add stregth to the base.
    The bend came out real well.
    Here is the inside base plate cut and fitted.
    Here is that plate inside the console.
    painting things up with the black dye/paint I used
    On the bottom I rivitted the two base plates together,sandwiching the fiberglass bottom of the console between them.You can kind of see the rows of rivits in this pic.
    The orig. wire that limits how far back the lid goes was missing.I went to my local hardware store and picked up some chain.Looks good and works well.
    The chemicals I used.
    The majority of the 2 layers of paint were taken off with the middle can of aircraft remover(bought at Walmart)It worked well.I got it down to the orig finish useing Acetone and a toothbrush.The can on the left is the dye/paint I used(bought at my local auto paint supply).The can on the right is call Molecubond.I used it to redo my sunvisors.I could have used it on the console as well.
    My cup holder was boken in 3 places.Again J.B.Weld was used.Here I've sanded down the excess J.B.Weld.
    spraying the cup holder with the same dye/paint I used on the rest of the console
    The finished product
    I purchased some clips for my "D"cell Mag Light at OSH(Orchard Supply and Hardware).I used existing holes in the back to mount the clips to the console.
    And that's basically it.I've got more pic's but this give you a basic idea of what I did.
  15. soup
    soup Newbie
    Oct 22, 2004
    4
    laguna beach
    Yo Rembrandt
    Mighty fine work my man, thanks for the quick tour it will get me going properly.
  16. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Looks great.
  17. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    very nice!
  18. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    SWEEEEEEEEEEETTTTT BobOOO :D
  19. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Damn,someone resurecdted this post.I did this 2 years ago now.
    I had updated the pic's a few days ago as the other pic. host(imagestation) won't allow remote hosting anymore.
    I updated the pic's as I posted a link to this thead for someone wanting info on redoing there console.
    Thanks anyway guys!
