Update on refurbishing my center console(PIC'S)
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by BobK, Jan 21, 2003.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Update on refurbishing my center console(PIC\'S)
    About 2 months ago I asked for tips on refurbishing my center console from my 71 Blazer.I took the suggestions given and went to work(I'm a slow worker) /forums/images/graemlins/grin.gif
    Here are the results.I think it turned out AWESOME!!!!
    Thanks to those who gave tips.
    Before
    After
    To see all the pic's I took while redoing the console click here
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Re: Update on refurbishing my center console(PIC\'S)
    Looks good as new. Nice work!! /forums/images/graemlins/thumb.gif
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    nice job
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Sweet resto Bro!! /forums/images/graemlins/thumb.gif
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Do you guys have to "sign up" to Image Station to view the rest of the pic's
    If so I can just post them here.
    Some-one let me know.
  6. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    Yea, you must have to. Or at least, I am not smart enough to figure out how to see more than just that one picture.
  7. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    O.k. I'll post em here.
    The bottom had a hole and a major crack that went the length of the base of the console.
    This is where the lid sits on.This cross piece was busted in half.I used J.B. Weld to fix all the cracks in the console.I bent up some 3/4" aluminium and rivitted it in place to help support this area.
    Here the lid has been stripped to the orig. finish and is ready for paint.
    I used 26 Gauge galvinized sheet metal to make plates for the bottom and the inside bottom.It covers the hole and will help to add stregth to the base.
    The bend came out real well.
    Here is the inside base plate cut and fitted.
    Here is that plate inside the console.
    painting things up with the black dye/paint I used
    the bottom.I rivitted the two base plates together,sandwiching the fiberglass bottom of the console between them.
    the orig. wire that limits how far back the lid goes was missing.I went to my local hardware store and picked up some chain.Looks good and works well.
    the chemicals I used.The majority of the 2 layers of paint were taken off with the middle can of aircraft remover(bought at Walmart)It worked well.I got it down to the orig finish useing Acetone and a toothbrush.The can on the left is the dye/paint I used(bought at my local auto paint supply).The can on the right is call Molecubond.I used it to redo my sunvisors.I could have used it on the console as well.
    my cup holder was boken in 3 places.Again J.B.Weld was used.Here I've sanded down the excess J.B.Weld.
    spraying the cup holder with the same dye/paint I used on the rest of the console
    The finished product
    I purchased some clips for my "D"cell Mag Light at OSH(Orchard Supply and Hardware).I used existing holes in the back to mount the clips to the console.
    And that's basically it.I've got more pic's but this give you a basic idea of what I did.
  8. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Cool deal! I had to refurbish mine, but it was so far gone that I bought another console (thinking that it was good). Found out that a lot of stuff was broken on the other one too, but everything that was broken on one was solid on the other.
    BTW, I used black oval head sheetmetal screws and J-nuts to hold the cup holder into the upper console to try to make it look as factory as possible.
  9. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    Why won't these pics display on my puter?
  10. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    nice work...does the rest of your truck look the same?
  11. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    where did the cupholder come from? my 71 has only the two slots for seatbelts and an ashtray in the center. I want to re-do mine. it is in pretty good shape now but it has a crack in teh side and teh hinges are pretty loose.
    great job on yours by the way!!!!
  12. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    The cup holders and the console were in the truck when I bought it.The cup holders must have been swapped in to the 73 and up design at some point.
    TONYP,at present my truck looks like this
    The paint and body are being done now.
    Thanks though. /forums/images/graemlins/grin.gif
  13. Steve_Chin
    Mar 6, 2001
    1,126
    The cup holders were part of the '73-up consoles. The console I bought was supposedly out of a '76.
  14. Stroked72Blazer
    Nov 9, 2002
    352
    Little Rock, AR
    LMC truck has the choice of w/ or w/out cup holders for '69-'72. I just assumed that ment they were available that way from the factory. They only sell them as whole consoles and they cost $140+ if memory serves correctly. I will probably use an aftermarket one designed for a J**p with locking top. Has any one seen one with a compartment for a CB that can be locked up and kept dry?
  15. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Bob,
    Those bodywork pics look "eerily" like what mine's going through right now....
    I stripped out the seats, and have been removing layers of old paint (some original, some not) and welding up about 40 holes in the bedrails, floor and bedsides, that were either useless....or from old rollcages, weird mounts, etc.
    I have started doing some "small" repairs on the floor (under the front seats) as confidence-builders.....just simple 5 x 7" patches to replace some metal that was too bent and rusty to deal with. So far I'm pretty proud of myself.....I grafted in a fresh piece of 16GA metal, ground down the welds and it now blends perfectly with the original floor!!!!
    I took a few shots of it tonight, but I'll prolly post them in the "CANCER SUPPORT GROUP" thread in the next day or so.
  16. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Greg,16 gauge,that's pretty stout stuff.You wheel that thing all the time though so I guess the "stouter"the better(is that a word?)
    I've been REAL lucky.The body is in GREAT condition.We're taking it down to the metal and the only substantial rust is in the areas you guys have been talking about in the "CANCER SUPPORT GROUP".
    Example #1-behind the rear wheels.Zero rust.Hard to believe after 32 years.
    Here is the cancer though.worse on the drivers side that the passenger.This is the drivers side.
    Anyway,I'll post a link to all the pics when I get it done. /forums/images/graemlins/grin.gif
  17. BigOrange
    BigOrange Registered Member
    Jul 29, 2001
    20
    Houston, TX, USA
    Bobk...sweet work on the console. Mine is in pretty good shape, but real dirty. I am going to follow your lead on this. Thanks for all the pics and details.
    I also need to clean the rear interior vinyl side panels. I tried some standard kitchen/outdoor cleaning products, but does anyone know of a product that really works well for this? also...the door panels need some love.
    Planning on getting some pics of the rig this weekend and will post ASAP. Exterior and mechanical resto is done. Came out great.
    Thanks,
    BigO
  18. '72brett
    Dec 3, 2002
    166
    northwest Iowa
    I have a custom made center console. I had it made at radio shack. I could have done it myself, but I really like the job they did on it. I have pics (not real good ones, but pics) in the link below. /forums/images/graemlins/thumb.gif
