Update to Possible Trans problem
Discussion in '1982-Present GM Diesel' started by shaffera, Dec 16, 2002.
  1. shaffera
    shaffera Newbie
    Jul 30, 2002
    3
    Virginia
    Well it is moving away from a possible trans problem(7000r4) to a good chance that it is a trans problem. I removed my transmission pan yesterday and found 1/8"-1/4" chunks of metal in the pan. I have talked to a friend that has a 700r4 and he had the same noise and he just bought a new transmission ($$$)..
    I am going this week to talk to a couple of local transmission shops to get some pricing and general info. I just wanted to know a couple of things so I don't make a fool of myself.
    Buying a rebuilt trans(700r4) vs. removing my old trans and having them do a full rebuild?
    Does a shift kit(not for performance but durability) make a noticable difference with a diesel,is it worth the extra money?
    I have read quite a bit on the 700r4, some people say it really isn't strong enough to last for long periods on a diesel and some say you definetly need a good trans cooler or certain stronger parts. Any thoughts or opinions??
    Finally any personal opinions appreciated, right now I have more time then money so suggestions and input is welcome
    Thank you.
  2. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    A shift kit will help with durability. A shift kit makes your transmission shift harder, and a harder shift means less clutch slip.
    I would just ask your local transmission guy how much for a rebuild. If your a little technical and have time, you could do it yourself for about 300.00 and thats with upgrades.
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Talk to other guys about which shops to use. Ask the shops for customers you can talk to. Its VERY important to get a GOOD shop to rebuild any transmission but especially the 700R4. IMO. Time well spent.
  4. shaffera
    shaffera Newbie
    Jul 30, 2002
    3
    Virginia
    Thanks for your help, I went around Wednesday and got some referrals through friends which have had transmission work done. I went to those shops and they said it would be best to rebuild the tranny that was already in my truck. For all upgrades and installed 1 year warranty (parts and labor) $1000-$1400. Each shop said it was probably my rear planitary gear after I described what I had found and how it had happened.
