UPDATE**Truck taking long time to start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Aug 9, 2002.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    8/15/02 Replaced relay. Truck starts like it used too! Thank god, and thanks for the help.
    Recently my K5 takes alot of cranking before it starts. It used to start fine but now it doesn't. I takes a bout 4-6 times of cranking before it starts. When It does start it runs perfectly.
    I replaced the fuel filter and temp sensor. Still does it. Wires on the starter are good too. I am thinking it is the fuel pump.
    Anyone have any input?
    Its a 1988 K5 350 TBI.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Re: Truck taking long time to start
    Does the fuel pump prime correctly? It should run for a few seconds when you turn the key to ON. This could be a bad relay. Wihthout it, the engine will have to crank until there is oil pressure for it to start. Then the fuel pump gets current from the "run" circuit.
  3. walt88
    May 24, 2000
    430
    Monmouth County, NJ
    Where is the relay in the truck?
  4. dyeager535
    26,978
    Wanna sell me that temp sensor?
    I agree with Blue's suggestion.
    I believe that the fuel pump wire on the ALDL connector should be getting 12V when the key is moved to the run position, so thats likely another way to test, besides the noise : )
    Dignosis is the name of the game, instead of spending more money on parts that might be the cause of a problem, buy yourself a "live data" scanner and a shop manual. It will save you money in the long run. Thats what the ALDL connector is there for.
  5. BUSCO
    BUSCO Registered Member
    Mar 4, 2001
    38
    New York(11552)
    The fuel pump relay is on the curbside of the truck, mounted on the firewall. Unplug the wiring harness to it and start the truck, if it takes as long to start as with it connected that would probably be the problem. If it is no good, or disconnected, the computer waits to see the oil pressure reach about 10psi before it will start. This is some kind of safegaurd.
  6. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    you are thinking in the rite direction its the fuel pump i had a 96 tahoe it would take a while to start the fuel pump was bad
