--UPDATE W/ PICS!-- When coasting at high speeds, doubler makes gear noises
Discussion in 'The Garage' started by dawson444, Jun 23, 2004.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    ---------------UPDATE-----------------------------------
    http://community.webshots.com/album/157702692oeRbuw
    there are some pics, what do ya'll think I should do? Thanks!
    I have a doubler in my truck behind a TH400. When I am on the gas everything is fine, and when i am at low speeds I am fine. When I get up to high speeds (around 50-60MPH, my speedo doesn't work) and I let off the gas and I am coasting my doubler makes some bad noises in the gears. As soon as I start to accelerate again it goes away. What could this be? Thanks!
  2. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Re: When coasting at high speeds, doubler makes bad gear noises, please help!
    FWP and I have been there and done that, we both changed our rear driveshafts and the problem went away. It's gear slop, and we both chased it for a year, if you already have a CV driveshafe in the rear, then that's a diffrent story.
    I must have pulled the cases down at least twice chasing the rattle. In the end we fixed it by using a CV in the rear drive shaft.
    Rob
  3. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    I already have a 1350 HAD CV in there. What else could it be?
  4. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,066
    190
    Colorado
    Any dents/dings in the driveshaft, Bad u Joints. Also check your rear output bearing. The housing that the bearing retainer is in is also the speedo housing on the 205. Maybe this bearing is bad.
    Check all of the easy things you can before tearing into the cases. There really isn't anything that can go wrong doubler wise. It pretty much has to be bad bearings or driveshaft related.
    Also you might give the rear end a quick once over. Bad Pinion bearing might give you this.
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Its not the Doubler.My guess would be your pinion angle is off.I think you can have up to + or - 4 deg. max difference between your drive shaft and pinion.Any more than that and you can get vibes and strange noises /forums/images/graemlins/grin.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    driveshaft angle
    turn up the stereo
    I wish I had a stereo in my truck to drown out that nice harmonic that recent bandaid work has created
  7. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    ok, i will look into those things. What is a good source for shims? Thanks!
  8. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I've got the same problem and I don't have a doubler. I've got a six in lift and both the front and rear shimmed as much as I could get away with and it still has the vibrations and noise. Definitly check your driveshafts and ujoints when I replaced them it helped a little.
  9. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    The driveshaft is brand new, I have less than 50 miles on it and it has been 4 wheeling 0 times. Are you running a CV shaft?
  10. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    Yeah I've got cv shafts front and rear.
  11. el diablo
    el diablo Registered Member
    Jun 12, 2004
    30
    Mt. Home Idaho
    I doubt it is a driveshaft, how is the doubler coupled betewen the tranny doubler box and tcase? Thats where I would look. Sounds like a worn spline issue.
  12. miniwally
    Aug 11, 2003
    3,066
    190
    Colorado
    There are so many things that this could be. Does your pinion look straight with the driveshaft? With the CV you need to run almost no angle at all at the pinion end of the shaft.
    Any bearing that has some extra play in it would sound like this.
    Like I said before look at everything before saying it is a T case. /forums/images/graemlins/thumb.gif
  13. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    update at top
  14. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    update at top
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  15. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    think I should just throw shims in it to try to raise the pinion up some? What degree do ya'll think? Any particular brand?
  16. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Show us pics of your driveline at the pinion and at the t-case, that would help. ANY driveline vibration gets amplified HUGE in the t-cases, especially at coast, because of all the gear slop that exists in the 203/205 combination.
  17. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    now its really updated, sorry for that.
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What does it look like from the side. It almost looks like you can up a couple degrees. I don't have a doubler, but I have a CV shaft. This is a good pinion angle :
  19. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Thats what I was thinking too. What size shims do you think I shoudl start throwing in there?
  20. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Sorry I edited my post. Shims come in 2 degree increments. I tried 2 degrees before I bought shaft, it does move it alot more than it sounds /forums/images/graemlins/k5.gif
