<update with pics> Sensor on TH350 transmission?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by anatomiczero, Jan 20, 2002.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    I'm curious, There's I believe is a sensor on the driver's side of the transmision and it has a wire coming off of it. Well the wire is cut and just wrapped around a hose. I pulled the sensor out and there's two plastic prongs with a conductor in the middle of one. What is this for and does it make a difference that it's not hooked up?
    I got a digital camera, here's some pics-
    http://home.attbi.com/~anatomiczero/jimmy/images/th350_angle2.jpg
    80' GMC Jimmy 4x4, 350-TH350-NP205<P ID="edit"><FONT class="small">Edited by anatomiczero on 02/24/02 03:19 PM.</FONT></P>
  2. anatomiczero
    Jun 26, 2001
    418
    Washington
    Re: Sensor on TH350 transmission?
    &lt;bump&gt;
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Sounds like the lock-up trigger for the torque converter from the distributor. Unhooked, it is basically acting like a non-lockup variant.
    The advantage of the lock-up is it is more efficient on the highway. When you are in third gear and the RPMs get to a certain level, the distributor triggers the torque converter. This makes the transmission work at a straight 1:1 with no lost power from torque converter slippage.
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/album/26246038MbQsYWKcbo>U.S.S. Nimitz II</a>
  4. anatomiczero
    Jun 26, 2001
    418
    Washington
    Thanks for the idea, I didn't see anything from the distributor, I'll check some more tomorrow.
  5. dyeager535
    26,980
    For awhile GM used some kind of system for emissions that had to do with gear selection and timing. Yours is either that or for lockup, I've never seen an "early" lockup plug though. Later ones are square with positions for 4 wires.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  6. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I've got an older TH350, and the single wire was for the TCS system which was connected to a solenoid circuit on the carb which would cut vac advance when trans is in a certain gear. So.. the wire tells the system what gear the trans is in. It is for emissions and I scrapped the system. It is a 1971 though, so I'm not sure yours is the same, but I assume so. JT
  7. anatomiczero
    Jun 26, 2001
    418
    Washington
    Thanks for the replies, I'm not gonna worry about it if it's just for emissions.
  8. anatomiczero
    Jun 26, 2001
    418
    Washington
    pics are on first post.
