**update** WTF! Valve clatter under power.
Discussion in 'The Garage' started by Okiemuddog, Nov 26, 2003.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Okay, I swear if anything else goes wrong with this truck I am going to sell it real cheap. Oay, here the story, swapped out my old tired 350, I bought a '91 engine minus Serp set up and TBI, I bought the Edelbrock #2104 manifold for the late model heads. I got everything together back together, timed it and set the carb. The problem is that it idles great, but I have some BAD valve clatter under peower, does not clatter while in park, starts with any power in gear. The other problem is I started before I left work, went back to get some stuff and came back out and it was idleing rough and at about 500rpm, the idle is set to around 1K. Got in it reved it a couple of times and it sounded like a diesel, decided to see if it would clear up on the road. I could not get it to do above 25mph and rattling like hell, so went back to work got a can of carb cleaner to see if the intake was sucking air, came back out and it was running right /forums/images/graemlins/confused.gif. So I head home, still have bad valve clatter but running correctly. The valves have never been messed with, came out of Wakeboard&4x4er's truck straight in to mine, he said he had no problems with it. This truck is really starting to piss me off, so plaese give me some suggestions before I sell the damn thing and buy a dependable DD ricer.
    Thanks Krennen
    Well, found part of the problem, I am running a TBI bottom and heads with a carb, me being my usual self, I never thought about the timing being different. I had timed it to 8* BTDC, well TBI engines run at 0* timing, retimed it, got lots of power now and minimal valve clatter. I am going to try runing some high octane through it and see if it will clear up the vavlve clatter I still have. Thank you for the suggestions and the help, I guess I will kep it another week until something else breaks. /forums/images/graemlins/rotfl.gif
    Krennen
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    Re: WTF! Valve clatter under power.
    sounds like you aint got the timing rite.or a vacum leak. play with it a little after you go settle down and drink a cold drink /forums/images/graemlins/tongue.gif
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Are you running a vacuum advance? Is it hooked to the right port on the carb(no vac at idle)? Too much vacuum to the advance pod will cause mucho pinging.
    Keep your chin up, brother. It will all seem like a bad dream when you get it fixed!!!! /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree, sounds like detonation, pinging, spark knock, whatever you want to call it, to me.
  5. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Update at top /forums/images/graemlins/thumb.gif
  6. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Thanks GOOD, what kind of @$$ sold you that motor...
    Glad to hear it is working...
    brett
