*updated 5/24* Front bumper and the fuel tank done, rear bumper done!
Discussion in 'The Garage' started by jjlaughner, May 4, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    its 6" x 2" x .188"wall (My buddy chris gave me 4 49" sections /forums/images/graemlins/waytogo.gif FREEBIE!)
    The brackets are 1/4", I started by making a top plate and bolting it on, I trimmed off about 1.5" off the front of the frame rails, clamped on the side brackets and tack welded them. Then I put the tube up to the brakets and tack welded it, pulled it back off and welded it up. Marked and use a torch to trim the ends and make the hole for the hitch receiver. Once it goes back I'n I'm going to but the body lift on and then there should be enough room to make some tubes come out and wrap under the fenders.
    Maybe tomorrow I'll start the side sections after i get the body lift put on, then next week I'll make a matching rear bumper (I'll bob 3" off the rear frame rails)
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Re: NEW PROJECT! More pics... Front bumper started
    That looks really good... did you do all that today /forums/images/graemlins/eek.gif
  3. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    looking good /forums/images/graemlins/waytogo.gif
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    yep started about 11am and worked on it on and off all day till about 10pm /forums/images/graemlins/thumb.gif
    Hopefully tomorrow I can start the outer edges if I get the body lift done (I have to grind down the diamond tread a little and make square holes because I'm putting in some extra long 1/2" carrage bolts I got for free /forums/images/graemlins/grin.gif).
  5. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    looking good JJ
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Wow your a hard worker!! /forums/images/graemlins/eek.gif /forums/images/graemlins/bow.gif
  7. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Only one question: Where's the diamond plate? It can't be JJL without gratituous use of diamond plate /forums/images/graemlins/laugh.gif
    -- A
  8. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I'd have slid a bracket over on each side to tie into the body mount.....
    Other than I think that you should have sunk the reviever in as far as possible, I love it
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    -- A
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    It was going to be all that 1/4" bar stock, then I was going to skin it with 1/8" diamond plate /forums/images/graemlins/whistling.gif
    Since my buddy gave me some free stuff that works (and is easier than bending diamond plate) I decided to use it. There will still be a diamond plate skid plate in the front /forums/images/graemlins/waytogo.gif
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    [​IMG] Front bumper from the side
    Got the body lift most the way on... all except the front two I'll finish it off tomorrow and get the bolts cut to length. Then I can start the rear bumper (I already have the brackets cut just need to mock it up and tack it together), then I'm going to trim the fenders just a hair more and do some more welding.
    -getting the pucks in the rear
    -then I took the high lift and lifted the passengers side till I had the jacksatand maxed, then done the drivers side.
    -under the drivers side
    -under pass side
    -trimmed rear frame rails
  11. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Did anyone ever tell you that your frame looks like it's going to break in half? /forums/images/graemlins/wink.gif
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I say it all the time /forums/images/graemlins/deal.gif
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  13. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    -- A
    jjlaughner is to diamond plate what rjfguitar is to big bling... It's like grammar school all over again. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    [​IMG] Can you jack your truck up by the floor! I was just skimming the photos and had to take a double take. Body lift OK.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  15. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, that's one way to get around the "how long do my body bolts have to be for a 2" body lift?" /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I just noticed that /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  17. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I dont complain about free stuff! I just said I need LONG carrage bolts and thats what showed up. /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
    The first 4" are solid and the other 8" is threaded /forums/images/graemlins/histerical.gif
    Bolts - FREE - Dad
    body lift - Free 3" I cut in half - JeremyK5 by way of Bigbird4wd
    6x2 tube - Free - Chris from KarsonRacing
  18. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    No offense, but I'm starting to hate that bumper
    The floor still rocks like hell though!
  19. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/deal.gif I'm making an Identical rear one /forums/images/graemlins/thinking.gif
    Its not quite done yet /forums/images/graemlins/whistling.gif
  20. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    It's just all brickey and sticking out there and not vapped and..... guhhh
    I just expected more cools tuff with that floor
    Gah I'ts my problem
    Did you get the front body lift done? How does it look now?
