**UPDATED** D60 Wheel Stud Size????
Discussion in 'The Garage' started by 90blzr, Nov 19, 2003.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    What are the exact size of the wheel studs for a front Chevy Dana 60...SRW? I used to have 16 of them,BRAND NEW but cant find them anywhere /forums/images/graemlins/angryfire.gif
    I just wanna make sure I get the right size from the parts store. Last time I went in, they gave me ones that were To short. And for the I cant friggin remember what the exact size is....9/16-? x?
    Thanks /forums/images/graemlins/tongue.gif
    <font color="blue"> **UPDATE** </font>
    Okay I checked on the Dorman site and it appears Dorman makes the PIK-A-NUT studs that are in most parts stores.
    Here is the info I found. I went off of a 1986 Chevy K30:
    (The actual DORMAN part numbers usually you can get in a box of 10 too.)
    FRONT SRW:
    Item Number: 98726
    Description: Wheel Studs
    Brand: PIK-A-NUT
    Application: Chevy/GMC Truck 91-77
    Attributes:
    Type : Serrated Stud
    Thread : 9/16-18
    Knurl Dia. : .650"
    Length : 2-17/32"
    Shoulder Length : 15/16"
    REAR SRW:
    Item Number: 98739
    Brand: PIK-A-NUT
    Application: Chevy/GMC Truck 97-71
    Attributes:
    Thread : 9/16-18
    Knurl Dia. : .622"
    Length : 3"
    Shoulder Length : 1-1/16"
    FRONT DRW:
    Item Number: 98716
    Brand: PIK-A-NUT
    Attributes:
    Thread : 9/16-18
    Knurl Dia. : .655"
    Length : 2-3/32"
    Shoulder Length : 27/32"
    REAR DRW:
    Item Number: 98741
    Brand: PIK-A-NUT
    Application: Chevy/GMC Truck 97-74
    Thread : 9/16-18
    Knurl Dia. : .621"
    Length : 3-17/32"
    Shoulder Length : 1-5/16"
    Now the actual DORMAN wheel studs usually come in 10 to a box and that part number is:
    FRONT SRW:
    610283
    REAR SRW:
    610189
    FRONT DRW:
    610282
    REAR DRW:
    610941
    WAGNER also makes the studs and part numbers are as follows:
    FRONT SRW:
    BD61381
    REAR SRW:
    BD61053
    FRONT DRW:
    BD61276
    REAR DRW:
    BD61393
    Thats all the info I have found and should be good enough /forums/images/graemlins/tongue.gif /forums/images/graemlins/thumb.gif
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    Re: D60 Wheel Stud Size????
    yeh i used to have the DORMAN part # but i lost it. a part # sure would be nice since i gotta go buy some.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have a question regarding this topic:
    are cheap discount store wheel studs actually cheaper quality ? anyone had any bad things happen with like auto zone or similar ones ?
    and what is dorman ? store? or brand of studs ?
  4. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    I agree, like I said, I had a box or two of them, and now that you mention it, they were Dormans. I just cant find them anywhere. They must have gotten lost when I moved everything out of my storage unit /forums/images/graemlins/angryfire.gif And if I remember, they were pricey little bastards too /forums/images/graemlins/tongue.gif
  5. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Actually Dorman is the brand name of the studs. I've seen them in the chain stores, but cant remember which one. It was about a year ago when I got mine. But I got mine from a little parts store that closed down since then /forums/images/graemlins/frown.gif
  6. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Anybody /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/deal.gif
  7. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I dont know either, but I went to a bigger stud when I rebuilt mine. I just brought in a stud so I could match the very bottom part that is a press fit into the rotor/hub (has to to be the same obviously) and a lug nut that was the size I wanted the stud to be. The stock studs in the 60 did not use the same size lugs nuts as the 14 bolt rear end I got, so I replaced them with some that did.
  8. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    TTT
