Updated Gear Ratio Calculator
Discussion in 'The Garage' started by zero cool, Apr 14, 2006.
  1. zero cool
    zero cool 1/2 ton status
    Sep 19, 2005
    150
    Austin, TX
    Just an update. Anyone who used my old gear ratio calculator, it's been updated and moved.
    The old pages are gone:
    http://www.dfw-tx4wd.org/gears.html
    http://www.dfw-tx4wd.org/Tech-Dept/Tech-Dept/gears.html
    The admin decided not to leave a forwarding page.
    The new page is:
    http://www.grimmjeeper.com/gears.html
    I added a bunch more transmissions and t-cases, including the new STaK 3 speeds. I also added a way to put in your own numbers if you want. I put in a bigger set of gear ratios and more tire sizes as well as the capability to change the RPMs and speeds it uses to calculate with.
    If you find anything that's wrong, please give me a shout so I can fix it. My email address is on the page. Otherwise, enjoy. And spread the new address around to anyone who has the old address and can't find it.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    hahahahahaha...you rock man! i've had this bookmarked for a long time it seems. I go to use it yesterday and it wasn't there. awesome, and thanks for the nice tool.
  3. zero cool
    Sep 19, 2005
    150
    Austin, TX
    So how do you like the upgrades? I've been meaning to do them for quite a while now.
  4. Mikey von
    Mikey von 1/2 ton status
    Dec 21, 2005
    1,550
    3
    Burney, CA
    Super cool. I did not get a chance to see the first page, but by far the best gear ratio calculator I have seen. I really like the comparison feature. All of the choices such as inches or metric are really cool tooo. In no way does it need improvement but, I would like to see a "calculate" button that floats or is in more places so you can make changes to things like "Road RPM" and not have to find the change button then go back down and look at your results. Awesome, awesome, awesome!
    I need overdrive for my burb and I am currently trying to decide if I should go with a built 700R4 or a NV4500. And 33's vs 35's.
  5. zero cool
    Sep 19, 2005
    150
    Austin, TX
    That's a pretty good idea. I'll see about adding a few calculate buttons.
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Man, that is awsome. I have always loved your calc from the first time I found it. By far the most usable one out there. I cannot say enough good things about the time you put into this. Thank you for doing it.
    Can you make the tranny/t-case gears fill in before you hit calc?
    Thanx again :bow:
  7. zero cool
    Sep 19, 2005
    150
    Austin, TX
    I might be able to make the fields fill in. I need to do some more research because I don't know enough about HTML forms.
  8. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    :waytogo: very cool.
  9. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah the upgrades are very nice. i had a friend quizzin me to death on how he'd rev with different gears in his tacoma at all these different speeds and your table made it possible for me to give him real answers fast.
    thanks again
  10. AuH2O
    AuH2O 1/2 ton status
    Oct 4, 2006
    185
    FL
    I'm giving this a bump! Great calculator, thanks a lot! :bow:
