UPDATED what is a slip yoke, and why is it bad FIGURED IT OUT ANOTHER ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Jan 19, 2002.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i see you guys refer to slip yoke eliminators all the time and was just wondering what it is
    my yoke is leaking at teh xfer case also and needs replacing
    what should i do?
    208-c new from boyce
    if the problem is you cant remove rear shaft and drive due to fluid leaking, couldnt you just get an old yoke, with out the driveshaft and slide it on the output from the xcase does the output shaft stickout far enough to drill through it and the repair yoke, if so, you could remove the drive shaft and slide on the repair yoke and slip a bolt and nut through and drive in front wheel
    just an idea for a cheap and easy alternative to the SYE
    also if the yoke is fixed to the output shaft like the diferential where does the movement happen for suspension flex?????
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's <P ID="edit"><FONT class="small">Edited by RESTORE89 on 01/19/02 11:43 PM.</FONT></P>
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    Re: what is a slip yoke, and why is it bad
    i have a 205 witout a slip yoke, so i dont know about the eliminators. but a slippyoke is when the yoke on the axle slides into the transfer case. on a fixed yoke t case the slipping is in the shaft itself and the shaft bolts to the case at the u joints. where the driveshaft "slips" into the T case there is a higher probobility of an oil leak occuring on the 208's etc.
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  3. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    slip yokes are simply as put before a yoke with splines that slip into the rear of the transfer case, I know there prone to leaking and if you break your rear shaft or pull it you'll dump all your fluid.
    78 K-10 383, TH-350, NP-203, Dana 70 front, GM 14bolt Rear, 4.56 gears(underconstruction) 78 k-5 stock and rusty
  4. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    The slip yoke eliminator is an aftermarket kit that converts your
    your yoke coming out of the transfer case to the same type of
    yoke that is on your rear end. A new drive shaft will be needed. No kit is mass produced for a 208 yet. You can convert a 241 though. Thats on my long list of things that I would like to have...
    Jim
    88 Silverado K5 5.7-700R-208-10 bolts-4.56-35in
    Procomp AT's- some ORD stuff & a CV driveshaft
  5. Storm Trooper
    Nov 24, 2000
    4,640
    I found someone that can make a 208 slip yoke eliminator for us. I have not checked out everything about it but Randy has built me a 4x4 E350 van and done other work for me. If he says he can do it, I belive he can. If your serious about doing one, give him a call.
    Advanced Four Wheel Drive Systems
    1102 South 200 West
    Salt Lake City, UT 84101
    Contact Randal Robinson
    Phone 801-521-2334
    FAX 801-521-2335
    E-mail info@afwd.com
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"8" Lift -<font color=purple>38.5's"[​IMG]....
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i have the parts to make a non slip 208 if anyone wants one , im in el centro cal
    always gets me home K10
  7. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i have the parts to make a non slip 208 if anyone wants one , im in el centro cal . i already did mine and have a few pics on my webshots page lemme know ...
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    when you have a fixed output at the case, the driveshaft will have a slip yoke in the middle or close to middle of it, look on the 69-72 blazers, youl see what I mean
  9. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    A drive shaft with out a slip yoke in the t-case is just like a front one. The front drive shaft on 4x4's telescopes on splines when the suspension moves. This what the rear one will do with the slip yoke eliminator. Just clarifying for those that didn't quite understand /forums/images/icons/smile.gif
  10. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Where can you get a driveshaft for a case that has a fixed yoke? Can you send in your old shaft and have it converted to the slipping style?
