***UpDated*** Where to mount MSD under hood?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DuneRunner, Oct 11, 2001.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Well last night I installed my MSD 6A in about 2.5 hours.
    The hardest part was mounting the Dang BOX. I ended up takeing off the small grill under the windsheild, and mounted the box up above the heater hoses. I put it all together and took it for a test run and once I got on the gas I could tell it had better throttle response. Once I figure out the proper gap I will let yall know about the Gas mileage later when I can do it on a long trip. GO Easy and many thanks to Phillip at MSD he is a great guy (he even was able to call me at work and help me out.) "Philly87 on CK5"
    Later KEN<P ID="edit"><FONT class="small">Edited by DuneRunner on 10/16/01 08:53 AM.</FONT></P>
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Re: Where to mount MSD under hood?
    I did mine on the firewall around the heater in a 85 with a/c barely squeezed it in and only used 3 of the mounting holes...making a mounting plate sounds smooth as well
    What? You think the hole is too deep? Lemme see...
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  3. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Cool :) thanks for the good words. The Box that I got didn't come with mounting hardware (got it from a friend) What hardware did you use to mount. Just some sort of self tapping screw?
    Thanks Again. KEN
    DANGIT it's not a bronco!
