*** UPDATED*** whining noises coming form down under
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Jul 7, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    (I forgot to mention that this noise only starts when it is hot outside 65-90 degrees)
    Does that change anything ????
    Ok Heres yet another problem Im having. My truck whines as I drive at first I thought it was in the steering but I think it is just when my truck is in motion. Any ideas???????? /forums/images/icons/confused.gif
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Re: whinning noises coming form down under
    check the level of your tranny fluid...
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    I checked it this afternoon. The level was good. Any other ideas?
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Could be a bearing. But where is the fun part.
    Check all fluids in diffs, and x-fercase. Check joints -usually click.
    Could also be a tire.... M/Ts???
    Good luck.
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    The 700R4 in my S10 whined before it blew... Are you feeling any slippage? Actually, thinking about it, it whined in gear and out of gear, so if your noise is only during motion, I'd look around the parts that only move in motion, T-case level, and diff's level.
  6. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Check your t-case fluid.
  7. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Check all your fluids, grease your U-joints, check for uneven wear on the tires, they could be howling, check your stereo for a good ground, make sure the dog isn't in the back seat whining /forums/images/icons/grin.gif
  8. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
  9. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    updated,,,
  10. dyeager535
    26,980
    Sorry, no answers if you've checked everything external. Drive it till it breaks. Start saving. : )
  11. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    65-90 is perfect not hot. i guess in juneau though 90 can be terrible.
  12. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I wish hot down here was 65 /forums/images/icons/tongue.gif . Anyways, Are your brake pads worn out? Maybe a wheel bearing? My tranny made whinning noises when it went out and I experienced no slipping, just late/erratic shifts.
    James
  13. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    From where does it whine? Front - back - middle?
    Any particuliar speeds when you notice the whine? Above 30?
    Good luck.
  14. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    it whines in the front
  15. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    What has been done lately?
    It almost sounds like your gears in the front end are new...
    Did you check the front-end for fluid?
    When was the last time it was replaced?
    Does the front end need any special additives?
    Good luck.
  16. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    how about the alternator??? i am just curious cuz mine went and it sounded like a had a PETE JACKSON Gear Drive timing chain :0 kinda interesting but still annoying, i upgraded mine to a higher amperage and the whine is no longer!!! /forums/images/icons/smile.gif hope this helps
    Ck1500
  17. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Nope nothing has been doen to the front end at all since I have owned it.
  18. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Time to do some more investigating. Change the fluids, etc.
    Let us know how the fluids look, etc.
    Good luck.
  19. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I'd check power steering pump, next alt pulleys etc...will it do it just in park when the engine revs?
  20. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    nope it doesnt do it in park even if I rev the engine just when driving. How hard would it be to replace the power steering pump? prices on one???
