** UPDATED ** won't start -- battery problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77Jimmy, Nov 15, 2002.
  1. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    ** UPDATED ** won\'t start -- battery problem?
    Problem solved. Took battery to Autozone, tested it. Battery OK, just low. They charged it, brought it home and it cranked right up. Thanks for the help! /forums/images/graemlins/grin.gif
    Been a couple of weeks since I last started up and ran my truck. Went out to start is up yesterday and nothing. No sounds, no nothing. Headlights wouldn't work, nothing. I'm guessing it's a dead battery??? /forums/images/graemlins/confused.gif
  2. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    Re: won\'t start -- battery problem?
    i'd probably say yeh it's a battery problem, since the lights don't come on. you can check the voltage with a meter, or just pull it out and take it to autozone or somewhere and have them charge it (if needed), and test it, it's free normally. are you sure that you didn't leave anything on? it should start within a few weeks, but maybe not a few months? the battery might drain some?
  3. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Nope, didn't leave anything on. I thought it was strange that it would die (assuming it's the battery) after a couple of weeks. I filled it up w/ distilled water a few months back. Oh well, I'll pull it out and take it to Autozone. Thanks.
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Check your connections first...
    Good luck.
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Electrical problems are [​IMG], I hate them, I hate them, I hate them.
    John
  6. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I had wired the Electric Choke to constant hot+ instaed of Ignition Hot+ this lead me to have dead battery! Although alittle more info on your rigs Bio would be nice. Shorts can drian the battery.
    Bill
  7. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Re: ** UPDATED ** won\'t start -- battery problem?
    I meant to take this ttt when I edited it but I guess that's not the way to do it.
    Just an fyi for the folks that had some suggestions on my battery problem. Thanks!
