Upgrades for 203
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SummitXMK, Jul 5, 2001.
  1. SummitXMK
    SummitXMK 1/2 ton status
    Jun 6, 2001
    141
    Idaho
    OK the 203 Needs some TLC. I need a new Chain for sure. Where is the best place to get a good Chain? Probably seals front and rear. Anything else I need? Also I read somewhere a long time ago about a chain tightner that was for 203 that was adjustable to keep the chain from slipping. Anybody ever hear about this? Also are there any other upgrades I can do besides a doubler or a 205. I don't do enough wheelin to justify this. This is mainly for crusing forest service roads in the summer and hauling my 2 sleds in the winter. (Which I wish would hurry the hell up and get here by the way. 106 just suck!!!
    78 K5 Cheyenne 240K miles and counting (praying)
  2. Grim-Reaper
    7,385
    Atlanta
    Rebuild it and leave it alone. If it's still fultime then your better off leaving it that way. The only stronger case that made it in out trucks is the 205. That being saild I'm being stupid and temporarily making mine Part time because my tires are screwed and I'm waiting on some axle swapping before new tires.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  3. SummitXMK
    Jun 6, 2001
    141
    Idaho
    I don't plan on making it part time. I just want a good chain that won't stretch. My buddy bought the cheapest chain he could find and it only made it a year before it started to slip on heavy hard climbs. That is what I wanted the chain tightner for. I figure with both of those my chain should last about forever.
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Milemarker makes the chain tightener, i think its listed on the 4 wheel parts site, but its pretty expensive, more than a new chain, i'd say buy a quality chain, and it should last for 150,000 miles at least
    RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
  5. SummitXMK
    Jun 6, 2001
    141
    Idaho
    Ok so who makes the best chains?
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
  7. SummitXMK
    Jun 6, 2001
    141
    Idaho
    Who sells Morse Chains? Also does anybody sell a gasket kit? It I have to take it apart all new seals and gaskets will be on order.
  8. RaisedK5
    932
    Long Beach, CA
    i think the last time i cracked mine open the gasket kit was @40 bucks a 4Wheel parts, but that was a long time ago, i'll be cracking into it tomorrow so i'll let you know when i go to put it back together. Check diff or trans shops/suppliers for the chain, look in the back of Petersons and call around.
    RaisedK5
  9. hey grim,
    ever rebuild a 203? or has anyone else? they want around $900 to do it my neck of the woods. the rebuild kit is only like $180 though. how hard is it for the average joe to rebuild. how much stuff needs to be pressed on or off? i'm real close to getting an adaptor from AA and putting in the 208 i have. unless someone can talk me out of it. the adaptor is only 200 bucks
    <font color=blue>Striving for K5 world dominance</font color=blue>
  10. Payador
    Payador Newbie
    Jul 6, 2001
    Ohio
    Hey Grim I converted my 203 to Part Time about 3 years ago and I wheel it hard but not often, does this compromise the durability of the 203?
    Danny Smith 81 Blazer "Whisky"
  11. Grim-Reaper
    7,385
    Atlanta
    What screws it up with the part time is the front doesn't spin so the chain doesn't spin and the case was designed to lubricate by oil slinging off the chain. There is a resivior in the tail cone that collects oil off the chain. Infront of the speedo drive is a plastic gear that acts like a pump. It feeds fresh oil to the tail shaft bearing to cool it and lubricate it. The big problem is you supose to put it in loc every 200 miles for a few miles at around 35-45 mph to get some oil into the resivior. This is often forgoten and the bearings burns up. Also a lot of the roller bearing in the top need the oil.
    If it hasn't been converted then it's never been starved for oil and the only thing it usualy needs is a chain.
    75 has never been converted and it's in so much better shape than the 79 we have that has been converted long before we got the truck. I have had to replace the tail shaft bearings, part time kit. As far as I know my 75 hase never been apart in 300,000 miles.
    I should be installing my chain soon. I'll try to do a tech story with pictures if I'm nut doing the last minute wrench fest.
    Grim-Reaper
