Upgrading a '70 to disk brakes
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by aksidentproan, Mar 23, 2002.
  1. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    Upgrading a \'70 to disk brakes
    Ok, I want disk brakes. I know i need the master cylinder, prop valve and booster. Im just going to get the whole axle to make it easier. Someone suggested I use an axle out of a later truck because the U-joints or knuckles were bigger or somethin like that. What year range am I looking at? I want it to have the same spring and shock locations and dont want a 10 bolt. Any Help would be great. Thanks.
    Evan
  2. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Re: Upgrading a \'70 to disk brakes
    Any D44 '73 and later would be good b/c it has the 297-X axle joints. The pre-'73 D44s have smaller 260-X axle joints from what I understand. The spring pads and shock mounts are the same as your current axle.
    Will
  3. aksidentproan
    Dec 8, 2001
    477
    Maryland
    How do I make sure I dont get a 10 bolt axle? Did certain trucks have 10 bolts and others have dana 44's? Thanks for your help.
    Evan
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The easy way to tell a 10B from a D44 is the cover. This will show you what to look for http://coloradok5.com/axleguide.shtml
    Also I think the last year for D44's was 78
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Whats wrong with 10 bolts? They are just as strong as a dana 44 and its easier to find parts for the 10 bolts.
    Dan
  6. aksidentproan
    Dec 8, 2001
    477
    Maryland
    There is nothin wrong with 10 bolts. I just have a place where I have access to very cheap Dana 44 parts. And I already have some new parts on my 44 that I would like to transfer over.
    Evan
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    okay, then you want to pick one up from a second gen blazer then.
  8. aksidentproan
    Dec 8, 2001
    477
    Maryland
    Correct. For the larger U-Joints and what not.
