Upgrading Dana 60 front axle pinion yoke?
Discussion in 'The Garage' started by madmike, May 5, 2006.
  1. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    For those of you who have upgraded their Dana 60 front axle pinion yokes, which U-joint size did you go from stock, up to? Did you choose a 1350 or 1410 yoke, and why?
    I plan on upgrading mine (big block power and air under the tires isn't a good combo for the stock yoke!):doah: Thanks!
  2. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    how do you know that? did ya break it yet? I figure dont fix it until ya break it :haha:
    hell im still running my old school 1979 gmc locking hubs which are some funky style where you turn the ENTIRE hub.... Grab old of the entire end and spin :haha:
    aint broke.. dont fix it is what I say
  3. OBD60
    OBD60 Newbie
    Jan 28, 2006
    Minnesota
    I have a flange set up on my K10. It is stronger and can run a greater angle. Call Jess at High Angle Driveline and he will fix you up. It is not inexpensive but worth the money imo.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I went with the 1410 because it can handle alittle better angle than the 1350 and I was ordering a new shaft from HAD anyway.
  5. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    1410 for the angle I have.
  6. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    1350 right now but I will be going to 1410 very soon.
  7. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Just got my front driveshaft from HAD and upgraded to 1410. Better angles so I don't have to shim my D60. 6" of front lift. I also went with the 42 degree CV and it is a monster.
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Yep went 1410 for the strength over stock and the angle capabilities.
    I have killed 2 stock yokes and 1 1310 u-joint.
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I got a spicer 1410 yoke off of evilbay for $25, soooo I am going 1410 :D
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got 1350, went with it cuz they are cheaper than 1410, and the local parts store has them instock unlike the 1410's which are special order i believe. i think a 1350 will hold up just fine in the front. im planning on staying with 1350 upfront, and then going 1410 in the rear eventually, when it comes time for the new driveshaft
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Yep a 1410 and 1350 are same strength, but the 1410 can handle more angle.
  12. madmike
    Jan 23, 2002
    496
    ohio
    Wow, a lot of people went 1410, looks like mostly for angularity reasons. I plan on probably using a HAD driveshaft in the front, unless I can get one made locally, so I think I'll give Jesse a call, and order a yoke from him! Thanks for the great replies!
  13. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  14. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    dont mean to hijack but are any guys on here running a 1410 cv for the front driveshaft? I was told by tom when I talked to him that with a 400/205 that there is not enough room to run anything bigger than a 1310 cv up front. This is due to the pan on the 400 being so wide and it wont clear. Is this true? Do I have to have an excuse to run a doubler now?
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
  16. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    youd almost think that guy knew what he was doing...:rolleyes::D:p:
  17. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I picked up my 1410 yoke at the junkyard :D
    For what sizes does the journal size change? I've used lots of Neapco joints in the past - different sizes mind you - but the journals were all the same and the caps could be swapped around. :confused: Does the journal size get bigger with increased cap-size on Spicer joints?
  18. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yeah! I think that guy musta been welding since he was 17....:eek1:
