Upgrading my 10 bolt
Discussion in 'OffRoad Design' started by GRIZZZ, Jan 10, 2007.
  1. GRIZZZ
    GRIZZZ Newbie
    Feb 8, 2006
    4
    Calgary Alberta Canada
    I have a 79 jimmy and have upgraded my rear 12 bolt diff with new bearings ,axles and an Auburn. I would like to do the same to the front. I would like to know what brand of axles and u-joints you would suggest? I run 33" swampers now and will upgrade to 38" Boggers in the spring when I install a lift.
    Also should I go with an Auburn,Tru-trac or do you have any other suggestions? I am also curious about increasing the splines from my now 28 spline axles in my upgrade.I use my jimmy 90% for wheelin now I started out thinking it would be a daily driver, My mistake!
    Grizzz
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    So you`re running 33 Swampers now, and will be going up to 38 Boggers? Thats a big jump for those axles, one I dont think they can make....Time to go 1 ton.....
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,066
    190
    Colorado
    If you are going to run 38" tires don't put a bunch of money into the 10 bolt.
    You already did a bunch of work on the 12 bolt and hopefully you can sell it cause you need 1 ton stuff.
  4. GRIZZZ
    GRIZZZ Newbie
    Feb 8, 2006
    4
    38's were my first thought only because I read I could up grade my axles drive shafts and 36's - 37's would be okay. And I thought I would push my luck further with 38's. So do you think these upgrades would be sucessful in my application?
  5. miniwally
    Aug 11, 2003
    3,066
    190
    Colorado
    36 or 37 inch tires with good axle shafts, u joints etc. is a struggle under a fullsize.
    38" tires are getting to mandatory D60 territory.
