upgrading to 12bolt this wknd
Discussion in 'Pacific Region' started by delta9blazer, May 3, 2002.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    anything i should look out for? i'm gonna try it solo, i hope i don't squash myself.
    is it as simple an R&R as it looks?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Drive shaft Ujoint??
    Shock mounts??
    Ebrake cable??
    Thease are the things that MIGHT be different than your 10bolt.... The good thing is they are both GM axels!
    Good Luck Bro!
  3. delta9blazer
    1,646
    are there any alignment issues i need to be aware of? or if it fits, it fits?
    and what about the angle of the dangle? anything there?
  4. Burt4x4
    6,854
    well your spring perch and spring packs will set the alignment butt you may need a degree shim to move the angle of your dangle?/forums/images/icons/smile.gif
    Not sure how different the 10 is compared to the 12, if any....??
    I know, no help right....
    Just slap it under there and go for a drive. If it vibrates then the angle is off, if it's smooth yer good to Go!!
  5. delta9blazer
    1,646
    ok, the 12b is under the truck, but the yoke and driveline won't bolt up. i pulled the yoke out of the 10b, but it won't slide onto the 12b shaft.
    is there a yoke that will fit the older 12b, but match up to my newer 10b?
    man, i wanna drive this bad boy!/forums/images/icons/smile.gif
  6. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Maybe a Hybrid "Me Joint" I mean YOU joint. /forums/images/icons/wink.gif
    I think that is what you would need. Sorry I to am probably no help...
  7. delta9blazer
    1,646
    and is this "hybrid" U-joint available at a NAPA or something? please please please?
  8. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Yeah Napa has them Me and a buddy did the samething when we swaped a 12 bolt in his 87 untill he could make a new shaft if you have both u-joints they can go off of that or if you know what year the 12b axel is that would work to .
  9. delta9blazer
    1,646
    it's done!
    got the u-joint at napa (#372), was driving just after noon on sunday.
    sweet.
  10. Burt4x4
    6,854
    Great!! Glad to here it worked out for ya!
    late
  11. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I'm glad that my wild guess worked out for you. /forums/images/icons/wink.gif
    Good to hear.
