Upper ball joint 4x4, how tight "nut insert"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by uglytruk, Mar 27, 2006.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    I just changed the upper ball joint on my '87 Burb, and am not clear on how and how tight to snug that threaded bushing. Included inst. say "show two threads", but it's hard to tighten it with stud sticking through it. Any suggestions...???
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You need the correct socket, or do what I have done before and make one. I used a 19MM, 1/2dr, deep socket and cut it into the correct shape.
    Do a search on ball joint change and you will find the torque value
  3. uglytruk
    Oct 24, 2004
    1,329
    Great, off to the China tool store for a cheapie 19mm. Thanks...
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
  5. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    yeah i made one too, its pretty easy
  6. uglytruk
    Oct 24, 2004
    1,329
  7. uglytruk
    Oct 24, 2004
    1,329
    Here's my nut/bushing tool, in action...
    A thinner (chrome) socket woudl've worked better The 19mm black was too thick, rubbed on the knuckle...
  8. uglytruk
    Oct 24, 2004
    1,329
    What about a seal behind the u-joint?
    ... all the crud that gets into the tube...
  9. uglytruk
    Oct 24, 2004
    1,329
    Step-Bumper for Sub, Same as PU?
    I've got a beautiful chrome step bumper on my '79 2wd PU. will it fit my '87 Sub? Obviously they're very similar, if not identical. Suprising never to have seen one so equipped?
    What about from a Dog or a Dorf. Just a little different around the tail lights?
