Upper Ball Joint Adjusting Sleeve...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burbinator, Sep 21, 2002.
  1. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Anyone know where to obtain the special, tanged socket for the adjusting sleeve on the upper ball joint? I must have had the misfortune of getting the green parts guys, due to the fact they look at me funny when I ask them...
    And, if memory serves, the "preload" on the sleeve is 50 ft/lbs?
    TIA...
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I bought mine at one of the discount/specialty tool shops. I've seen them at some auto parts stores too, but can't remember which ones don't believe, however, it was the large chain ones, i believe it was some of the smaller ones around here. Try looking up tool stores, then call 'em and ask if they have automotive tools. If memory serves, I think I may have seen it at sears, but don't quote me on that one. Mabey do a web search and buy it online???
    The proper torque is 50ft/lbs, as you describe.
    BlazerMan
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I just bought one at an Auto Value parts store.
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I couldnt find them anywhere so i had my brother get me one from his MAC dealer.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    View this and read it.
    I got my Snap-On socket for around $15. The adjusting sleeve should be torqued to 65 ft. lbs. You should have instructions with the ball joints and it will list the proper torque. /forums/images/icons/wink.gif
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Balll joint spanner socket
    That is an OTC one, NAPA deals in OTC tools.
    The instructions in the set that I just did said 50 ftllbs
  7. sluggo45acp
    sluggo45acp 1/2 ton status
    Jan 2, 2001
    472
    Northern fortress, Republic of Texas
    I got mine off the Mac truck.
  8. rh88k5
    rh88k5 Registered Member
    Sep 11, 2002
    94
    Burlington, N.J.
    I made mine, used a steel pipe nipple, cut away material to form the prongs with a die grinder, then welded a 3/4 inch nut to other end, worked for me, I used it this morning an torqued to 50 ft lbs, any more may be to hard on the tie rods. Measure the force needed to pull pull knuckle with a fishing scale, should be 20-25 lbs. Hope this helps.
  9. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Thanks guys...
    Consider this a global thank you, since I cannot do a response to multiple people!
    I have a friend of mine that gets visits from the MAC Santa, so problem solved!
    Thanks again...
