Upper ball joint loose *UPDATED*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Triaged, Jul 2, 2001.
  1. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My upper ball joint is loose. Not the joint itself but the tapered part that goes into the axle inbord knuckle. The cotter pin is still there and the nut hasen't turned. When you shake the wheel the you can see the nut move. I can't loosen or tighten down the nut even with an impact (it spins the ball joint).
    Now to the question.
    How can I get it apart to replace it (I have a new one)? Am I going to run into other problems? If the threds in the inbord knuckle for the ball joint preload insert are messed up is there any thing I can do.
    I am going to start on this on wed.
    Any sugestions?
    '71 Blazer CST with alot of rust<P ID="edit"><FONT SIZE=-1>Edited by Triaged on 07/06/01 06:04 PM (server time).</FONT></P>
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Re: Upper ball joint loose????
    First you can try and grease the sucker up... either through a fitting or if no fitting get a pointed grease gun fitting and poke a hole in the rubber boot and try filling it that way... chances are you will have to get a prybar out and pry the knuckle and or jt differenet ways till you find a way that stops the stud in the b-jt from spinning. Kinda PIA.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  3. Storm Trooper
    Nov 24, 2000
    4,640
    I've had this happen several times on my work trucks (F*rd 460 4wd van conversions). It is a MF but if you can hit it up into the tapper enough or pry up under the nut to get it to loosen without bending the crap out of it then great. Spray the nut down with WD40 today. Most of the time this still doesn't work so if it doesn't, take a torch and heat the heck out of the nut, then while prying up some try to loosen the nut. It normally won't work until it cools down (expansion/contraction thing). If you still have no luck, drill a hole in the end of the pin, insert a easyout and use it to hold the stud while undoing the nut. After you get it out, check the fit of the new one, if the taper is screwed up, you may need to replace the part. If you really don't want too, I would use a little stud and bearing mount locktight on the stud when I put it together to help hold it in place tight. Good luck man.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    When this happens to me I drill 4 holes in a vertical line down the side of the nut .Once thats done you can hit the nut across the holes with a chisel or an air hammer.This splits the nut and it comes right off.Good luck.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I got it off! I drilled holes in the nut and than used a chisle to finish it off. Now I just have to take the nuckle in and have the old one pressed out and the new one pressed in. The threds for the insert are fine so all this will cost me is the $15 I payed for the balljoint and some time.
    As a side note I love that you not only can, but have too beat on these trucks with a BFH. Great way to releave frustration.
    Thanks for all the help.
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI, learn and understand the term "Upper Ball-Joint Pre-Load"
    Good luck
  7. Grim-Reaper
    7,385
    Atlanta
    Pick up a haynes manal at the parts store. There is a procedure to be followed when installing the ball joint and there is important torq values for the prelaod sleave. It sounds like it wasn't preloaded properly before and that's why you had the problem in the first place.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I read the section in the manual. It says to torque down the adjusting sleve and then the nut. I have a adjustable spanner wrench but not one that will go on a torque wrench. Is there anyware that I could get one or is there another way to do it besides trial and error.
  9. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: Upper ball joint loose? *UPDATED*
    What now? I need the 4lug x 1"O.D. (I think) socket for the upper balljoint adjuster sleve. The spanner wrengh I have won't fit in there. None of the parts stores around here have the socket that will fit it (if you can even get them to understand what it is you are looking for). Does anyone in SoCal have one that I could barrow? Does anyone know where I could get one? I need to get this thing back on its wheels this weekend.
  10. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you can probably fab your own. just look for a pipe with the correct diameters or use an old socket and grid it to fit in. I got mine at "all under car parts" or something like that($15). you may also try a tire shop like winston/bigO/firestone and "rent" one from one of the mechanics.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    <blockquote><font size=1>In reply to:</font><hr>
    Good luck
    <hr></blockquote>
    [​IMG]ROTFLMFAO!!![​IMG]
    I knew when I read the subject title of this post, Executioner was going to say this quote!!! [​IMG]
    Man, you just kill me!!! [​IMG][​IMG][​IMG]
    BTW, I'm going to repeat Executioners post too!!!!! Learn and understand the term, "upper ball-joint pre-load". Man! That felt good to say!!! [​IMG]
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hey guys, a shop charged me $45 to replace ALL of my balljoints....then you don't have to understand that term!
    Tim
  13. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Upper Ball joint pre-load!!!! [​IMG]
    Wes, I was thinking the same thing. You know the funny thing is that I've put about 6k on my ball-joints since I replaced them and I haven't had no problems with them. They are still 4.0 and I didnt check no upper ball jopint pre-load. The instructions for the new ball joints didn't even mention the term, upper ball joint pre-load. I wonder why???
    Maybe they haven't talked to Executioner yet, you think?????
    When in doubt.....Use the Saws-all[​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  14. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I got tired of looking for the stupid spanner socket to put them in so I bought a cheep home depot socket and will brake out the die grinder in the morning. I also have to buy a stupid 1-5/16" socket which everyone only makes in 3/4" drive so I have to get the adapter too. This is starting to be more money than I wanted to spend (going broke after the 36" TSL's that have yet to be driven on).
    How often should this be checked? When I put the axle in 3 months ago they seamed tight.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  15. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I feel ya man. I was in there doing a simple brake job, and turned out I had ended up spending over 300 bones, with ball joints, bearings, rotors, pads, yada freaking yada....
    AS far as how often they should be checked&gt;&gt;&gt;&gt; ? (scratching head)
    I would check them everytime the manual says to the wheel bearings. If you get wobble, check the bearings, if you still have wobble then look at the ball-joints.
  16. Grim-Reaper
    7,385
    Atlanta
    Well your looking at it wrong. If kept lubed ball joints usualy go for 20years.
    Yeah that tool is a hard one to find. I made mine out of a socket also.
    Somebody posted a NAPA part number long ago for the right tool.
    When I got my truck I spent $500 fixing the front axle so don't feel bad. Everything that could go wrong was wrong. Carrier bearings had md in them, EVERY seal was shot. Ball joints, Itie rod ends, bent tie rod. you name it, it is new on mine.
    Grim-Reaper
  17. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've got the Snap-On number - S9613. Costs $14.80 from them, so I'd guess around 7-8 bucks from Napa.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  18. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Wow, I can't believe what I'm reading! It's literaly what I was about to write as a new post (except for the upper stud spinning)!
    I literally just went through everything posted by triaged, except I ended up loosening the adjuster with a screwdriver and hammer initially.
    And I too see that NOONE locally carries that part/tool (dealer parts guy looked at me like I had three heads). I did get a chevrolet tool number for it though from my new balljoint instructions...
    I started this job wednesday, wrapped up with just the bearing re-packed, restarted thursday, wrapped up with a badly beaten upper joint, but all still in the truck, and restarted friday, finally finishing the job. Every day I started over from scratch, cause I had to drive the truck each night...
    I took it to my machine shop to have the old upper pressed out (the only one I couldn't beat out), and the new ones pressed in, and they wanted $36, 45 minutes, and they were going to take off the steering arm and not replace any nuts or studs (bad, according to haynes).
    I then took it to my junkyard buddies, we stuck it in a vise, and in 5 minutes had the old out, new in, for free.
    I'm driving around now with the borrowed pickle forks, borrowed 1-5/16 wrench, and 1-1/8 socket all jinging in the back, but the job is done, my steering and cornering feel like I'm driving a vette!
    Ratch
    <A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
    **K5 - What more is there to life?**
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I took my whole axle to the shop with it stripped to the knuckles and it cost me $45 to have my balljoints pressed in.
    The steering arm can be removed without replacing the nuts...I've done it a million times.
    Tim
  20. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I hear ya! I looked all over the place and no one had a 1-5/16 socket in 1/2 drive so I ended up getting a 3/4 drive one and a adapter. I used a deep impact socket to make the ball-joint adjuster. It took about a hour to do. Than I started on the rear...The fill plug is frozen in place (now I have a eazy-out as a fill plug because that is stuck in there too), the retainer bolt for the spider gear shaft broke and had to be drilled out, and I noticed that the rear axle housing is cracked where the tube goes in! Hope I still have the time to finish all this and the cash for gas so I can get to Blazer-Fest.
