Upper ball joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by turbo, May 31, 2000.
  1. turbo
    turbo 1/2 ton status
    Feb 18, 2000
    109
    What is the deal with upper ball joints on solid front axle
    chevy 10 bolt.
    I have been told that some felt play when jucked up on a floor jack is OK as the ball joint is not designed to be tight untill under load (weight on the wheel). Is this accurate?
    As long as tight when weight on wheels it is OK?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    NO!
    balljoints should NOT move at all with no wieght on them.
    If you can rock the tire up and down then they are going bad.
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I second that!
    Mike
    82 GMC Jimmy "Emmett" "Built for function, not for beauty!"
    IN TOO DEEP Off-Road Club
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    If you can do some reasurch on this matter you will learn alot.
    Try to understand the "Upper Ball-Joint Pre-Load Spec. "
    See if you can idendify the "Sleeve "
    Good luck
