UPS just delivered my Dart intake manifold
Discussion in 'The Garage' started by Z3PR, Jun 14, 2004.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    and guess what, .... yeap, you guessed it, emory cloth time. /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif Need too clean up some castings. /forums/images/graemlins/ignore.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  3. lason
    lason 1/2 ton status
    May 31, 2004
    105
    Arlington TX
    I have heard some bad stuff about those intake gaskets. What I heard was that they didnt make any difference when new and eventually the screens came loose and trashed a motor, but that is just "I heard from a friend of a friend" kinda thing. The carb on the other hand rocks, I love demon carbs!
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]I've used those gaskets in the past on a few different engines and never had a problem with them, but I could see it happen. Probley just go with a set of Felpro, cheaper. For a cam, I'm thinking [ QUOTE ]
    249-CL12-211-2 Magnum 270H Hydraulic Flat Tappet Camshaft & Lifter Kit
    Lift: .470''
    Duration: 270°
    RPM Range: 1800-5800
    High performance. Biggest cam with stock converter. Use lower gears. Mild rough idle.
    Operating Range: 1800-5800 RPM
    Duration Advertised: 270° Intake / 270° Exhaust
    Duration @ .050'' Lift: 224° Intake / 224° Exhaust
    Valve Lift w/1.5 Rockers: .470'' Intake / .470'' Exhaust
    Lobe Separation Angle: 110°
    [/ QUOTE ] This is for the El Camino. I'm still waiting on the World Products Sportsman 2 intake for the K5.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    ought to be a potent driveable camino /forums/images/graemlins/thumb.gif
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]Well, it will be. Planning on building a 327, close to 11 to 1 compression. a 700r4, and a posi rear with 3.73 gears. But like everything else, it'll be awhile with my low to no budget. Bills come first.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I need to build something fast, crawlings fun but you need some speed thrown in at times /forums/images/graemlins/wink.gif. What heads you going to run? I remember you were talking I think Sportman IIs, but I forget.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Decided to go with these. Normally go with whe World Products heads, but because of the higher compression, I'm going with Aluminum Cylinder Heads this time.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    And I'm thinking one of these. and 8 of these /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/whistling.gif
  10. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    What tranny are you going to run? The reason I ask is because I'm going to make one of these for my Demon on the blazer.
    I could make one for you, but I am running a TH400. So, I'm not going to make a tranny kickdown bracket. Let me know. I'm working on finalizing the design now. It will be made with 1/4" aluminum plate. I can tell you it will be cheaper than the $75 that Holley wants for theirs. I can even engrave Z3PR on it.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    700r4
  12. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    So you would need a tranny kick down huh.
    I just didn't like the way I had to rig up a throttle cable bracket. So I saw these made by Holley and decided to make my own. The regular brakets at the local Checkers won't work because of the way the base plate is.
    Let me know if it still might work. I'll get you a finished product drawing.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thats really cool of you. It'll be quite a while, I'm still in the parts gathering phase. Smaller items will be tords the end. But I'll get ahold of you when the time gets nearer (When I'll have some more money to spend)
