upside down shocks
Discussion in 'The Garage' started by desertrat67, Sep 26, 2004.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Can most shocks be run upside down or are they designed to be run body down? I don't want to get my rear mounts on the axle relocated. Right now the body gets crushed against the axle tube.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    most shocks are not able to be mounted both ways. Your standard Rancho or Skyjacker shocks must be body down or they won't function properly.
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Rancho 9,000 series can be mounted upside down. /forums/images/graemlins/thumb.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    "As a rule you should not run a dual-tube shock like this RS9000 upside down. Monotube gas shocks such as a Bilstein can be mounted with the shock can up or down, but most dual-tube shocks will develop an inch or more of “dead space” where an air pocket forms if you mount them improperly. Bottom line: Mount the shocks in the orientation the manufacturer recommends." -4WheelOffroad.com
    http://www.4wheeloffroad.com/techarticles/67238/index1.html
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    my DTs are twin tube, and the manufacturer says its no problem to mount them either way...
    j
  6. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    thats doestsh, doetch, doesth, tech right?
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    You better go look at Rancho's website, they say the 9,000 series shocks can be mounted in either direction. /forums/images/graemlins/thumb.gif
  8. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    thats affirmative.
    j
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I think I've heard you CAN but they operate better in the normal way. I am completely blanking on reasoning so unless someone says otherwise I must be wrong /forums/images/graemlins/wink.gif
