URGENT: 14BFF Carrier Removal/Installation
Discussion in 'The Garage' started by willyswanter, Sep 28, 2003.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I need to pull my carrier on my 14 bolt so I can replace my pinion pilot bearing, race hits the ring gear. Anyway, are my steps correct here?:
    1) Check backlash
    2) Remove carrier and do my work
    3) Replace carrier and adjust till backlash is where it was when I started.
    Right?
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    yup that sounds right. Use a punch on the adjusters to mark your spots and count the turns so you can put them back where they were.
  3. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Woh, ok I think I found my rearend noise problem...
    The carrier is actually moving a bit left and right and forward and back
    I checked the backlash with the carrier moved away from the pinion and it was .013 and with it pushed against the pinion it was .009.
    So, my question is, what are the "used gear set" backlash specs? It looks like I'm going to need to replace the carrier bearings and I need to know what to set the backlash at once it's replaced since I can't get a good reading now. Or shoudl I just spit it and run .011? I know the new gear set specs are .006" - .010" but I am not sure if this should be the same for used gears, I Know the pinion preload is different for the used bearings.
    Whatcha think. Think this is why I had gear whine and bearing noise all the sudden? /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
  4. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ok, I got the carrier out. Carrier bearing races have spun in the carrier bearing caps... The caps and housing look fine, no grooves or anything and it doesn't look like they spun alot. So I'm going to pick up a new set of carrier bearings tomorrow and install them. Any idea what could cause the bearing preload to back off and the races to spin???
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't recall having to remove the carrier to get out the pilot bearing...I thought you just had to take the pinion support out? It has been a long time sence I did mine (chewed up the pinion when it went out...why couldn't they put a inner race in there /forums/images/graemlins/angryfire.gif).
  6. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    How did the carrier bearings and races look ? Any pic's ?
    It might be possible that you put way to much preload on the carrier bearings and burned them up - causing them to wear out quickly and giving you the additional clearance all of the sudden.
    As far as the back lash - it does not need to increa/decrease with a used set of gears but you do have to set the pattern up to the established pattern that is already ther if you expect good gear life.
    Good luck , Tom
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    As far as everybody I talked to that is very hard to do. If you are talking about the adjuster rings I don't know how you could get them that tight...they are pretty soft metal, and i doubt you can get the bearing caps too tight. Just my opinion.
  8. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I followed the instructions and it said to use a 10" spanner on the adjuster rings and I quote "you could lean all your weight on the spanner and still not put enough load on it to wear the bearings". Or something like that...
    Anyway, I know the caps were torqued to spec to. The bearings looked good. The races looked good on the bearing side but it was marked up from spinning on the other side.
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Jason...set-up specs here.
    http://www.ring-pinion.com/tech/techind.html
    I did alot of reading on the subject when I set mine up. Spec for back lash is .006-.010. With the lower end of the scale being best. With your carrier wandering around in the housing like it did, trying to match the original bl settings would be pointless. Set it to spec. There is also no spec for carrier bearing pre-load. I have read the "use a 10" spanner" method, but I think thats way to much. Zero preload or just slightly more would be best I think. /forums/images/graemlins/pimp1.gif
  10. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Umm, I thought the more preload the better as long as you don't go too much... Thats at least what I've read in the past... I was thinking that I didn't set enough preload which caused the carrier to become loose once the bearings seated and wore a bit... But then again I may have set them too tight and they wore way too fast and it became loose... But the bearings look good /forums/images/graemlins/crazy.gif
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Also, if the races spun in the housing, (assuming the cap bolts were torqued correctly) then something IS out of spec. The races are NOT supposed to spin in the housing/caps. Thats something you need to look at alot closer.
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    If you are using new carrier bearings, then pre-load obviously needs to be more, to account for the break in period. I've never had to replace 14b carrier bearings, so I've never worked with new stuff. /forums/images/graemlins/tongue.gif /forums/images/graemlins/rotfl.gif
  13. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ah well yeah ok then... I'm going to be using new stuff /forums/images/graemlins/tongue.gif
  14. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Stupid question, but do you have the locks to keep the adjusters from rotating in the housing?
  15. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep sure do. Thats one of the reasons I'm confused...
  16. zcarczar
    Feb 10, 2002
    2,495
    How tight did you have the bearings? When I was taught how to do rear ends the technician told me to set the preload till you could barely move the ring gear while holding your hand against the housing. Thats the way I have done all the rear ends ive setup and they all work fine.
  17. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I'm not quite getting this... Can you explain?
    What I'm thinking is I didn't get enough preload on there and when the bearings seated and got broken in they loosened up way too much...
  18. zcarczar
    Feb 10, 2002
    2,495
    Ok, lay the back of your hand against the top of the housing where the cover bolts on. Then put your pointer and middle finger on the ring gear and use this as your "gauge." You should be able to move it, but it shouldnt be extremely hard or extremely easy. I wish you were about an hour closer because I would come help you do the gears.
  19. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ok, got it all done today. I set the preload how you said and set it way looser than I did origionally. I set it about how I did before and I could barely turn it with one hand grabbing the ring gear let alone a couple fingers... So I set it to where I could turn it with my two fingers with some effort and it runs pretty damn nice now... No more noise which = good. /forums/images/graemlins/thumb.gif
  20. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
