URGENT! Brakes not working
Discussion in 'The Garage' started by anatomiczero, Sep 4, 2002.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    My brakes were a little mushy, so I checked the fluid and there was close to an inch from the top to where the fluid was. So I put some fluid in pretty close to the top then it spilled over some when I put the cap back on.
    The brakes got harder to press and took a while to stop like if the engine was off. So I scoop some out, but that didn't help. Please help!
  2. anatomiczero
    Jun 26, 2001
    418
    Washington
    I'mgoing to bleed the brakes, will that fix it or is bleeding just for mushy pedals?
  3. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    Bleeding them should help. As long as there is no leak anywhere. Make sure you have someone help you pump the brake and hold it while you bleed them. If you can get it to a break shop they can power bleed them for a few bucks. With a power bleed you will stop like no other.
  4. anatomiczero
    Jun 26, 2001
    418
    Washington
    Thanks, I'll tell my dad to either take it to shucks (close to home) or bleed it himself.
    edit: It barely stops, he'll bleed it, then maybe take it to the shop.
  5. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    Here's on more to think about...
    If it's power brakes make sure your vacuum line is secure. If you don't have the proper vacuum supplied then you'll have manual brakes.
    When in doubt bleed the brakes, definitly. Remembering the order of coarse.
